ported box for jl audio 13w7 opinions
steveskal
Copper - Posts: 56
Posted: November 28, 2007 at 12:24 PM / IP Logged
Hello all, I am just trying to decide on a box for this speaker. All of the ported boxes I have seen have the speaker and port on the same side. I have spoken to one box builder who says a box with the speaker firing up and the port firing back is the way to go?? What do you think about this, the box will be in a 2002 Escalade with a 1000/1 amp on it. Thanks!
tcss
Silver - Posts: 1,623
Posted: November 28, 2007 at 12:43 PM / IP Logged
Build the ported box from JL's websight.
There is no such thing as free installation!
steveskal
Copper - Posts: 56
Posted: November 28, 2007 at 1:03 PM / IP Logged
The only "design"  they show on the site is speaker and port on the same side. As far as specs go, lets say both have the correct amount of cubic feet as per JL Specs, again, I just want to see if the speaker firing up and port back is better..worse..indifferent, than firing back with the port.
aznboi3644
Gold - Posts: 2,600
Posted: November 28, 2007 at 4:34 PM / IP Logged
experiment with different styles and positions.
build two boxes...one with sub and port on same plane and one with sub and port 90 degrees off axis.
then see what style and positioning sounds the best to you
DYohn
Moderator - Posts: 10,741
Posted: November 28, 2007 at 6:01 PM / IP Logged
In a car, it is usually best to have the speaker and port on the same baffle.
tcss
Posted: November 28, 2007 at 6:12 PM / IP Logged
If the speaker firing up and the port firing toward the rear was vastly better don't you think JL would recommend that?
boogeyman
Silver - Posts: 359
Posted: November 28, 2007 at 6:34 PM / IP Logged
  it is usually ideal to have the speaker and port on the same plane as one another
steveskal
Copper - Posts: 56
Posted: November 29, 2007 at 12:17 PM / IP Logged
This kind of defeats the purpose of this post. I'd rather not waste the time, the extra money and effort if someone on the forum could offer some good insight. I'm not going to build to boxes and play trial and error.
aznboi3644
Gold - Posts: 2,600
Posted: November 29, 2007 at 4:19 PM / IP Logged
not really..you asked for our opinion. I gave it.
steveskal
Copper - Posts: 56
Posted: November 29, 2007 at 5:08 PM / IP Logged
Ahhh yes I see. So if someone asks what speakers are better for his car are you going to recommend he go out and purchase several sets so he can "try them out" and see whats best?? Lets use some common sense here.
