Posted: February 22, 2008 at 4:11 AM / IP Logged
Posted: February 24, 2008 at 10:15 AM / IP Logged
Posted: February 24, 2008 at 10:31 AM / IP Logged
Posted: February 24, 2008 at 2:20 PM / IP Logged
Posted: February 24, 2008 at 11:03 PM / IP Logged
Posted: February 25, 2008 at 5:53 AM / IP Logged
Posted: February 25, 2008 at 6:29 AM / IP Logged
Posted: February 25, 2008 at 7:58 AM / IP Logged
Posted: February 26, 2008 at 6:39 AM / IP Logged
Posted: February 26, 2008 at 8:38 AM / IP Logged
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
This is how i think this should be done but i definetely have a fault since the pink wire goes to ground when the ignition is switched on when alarm is in arm, hence shorting the ignition 12v to ground.
Thanks for your help.
I have connected the orange wire to the brown wire (which then goes to fuse box - ACC).
The grey wire of the ignition switch also goes to the IC Igniter of the bike. Hence could be causing the no-spark-problem. Will check this soon.
