2012 Kia Sportage Remote Start Pictorial
chev104275
Gold - Posts: 1,436
Posted: January 05, 2012 at 6:19 PM / IP Logged
This one is a 2012 Kia Sportage Non-Push start using a 4103
2012 Kia Sportage Remote Start Pictorial -- posted image.
Drivers dash has 2 phillps head screws in the 2 bottom corners
side of drivers dash is held in by plastic clips
On the side of drivers dash there 2 more phillps head screws
5 10mm bolts how the metal in
Phillps head screw on both sides
Phillps head under column shroud
shot of the front of fuse box bottom Lrg connector is the one with the locks and FAD wire
i usually unplug this and remove the gray top
Lock- Blue/Black
Unlock- Gray/Black
Factory alarm Disarm- Red
Drivers door unlock relay-Yellow/Black in back of fuse box. Need to tie this in with the unlock wire using a diode in between the too(diode band facing Starter)
Hood pin- RED / Black
Connector unplugged where hood pin wire is
Horn- White
Parking lights-Blue at light switch
Ingition Harness Ingition-Green, Acc1-Blue,Acc2-White,Starter-White,12v-Red,12v-Pink (Sorry for the bad pic)
Tach-Black at cylinder 4 coil
One I forgot is the brake wire -blue at brake switch
Platinum - Posts: 7,828
Posted: January 06, 2012 at 6:37 AM / IP Logged
Great info, thanks!  Still no transponder immobilizers in the U.S. market 2012 non-PTS KIA's?
chev104275
Gold - Posts: 1,436
Posted: January 06, 2012 at 8:54 AM / IP Logged
No nothing on those   just on the high end sedonas and borregos   all I've seen with the transponders.
Posted: January 06, 2012 at 5:19 PM / IP Logged
Nice. I see Ze Koreans are using ze Cherman quadlock plugs now (Mit ze poor Cherman accent).
chev104275
Gold - Posts: 1,436
Posted: January 06, 2012 at 6:28 PM / IP Logged
ha ha ha Howie I will agree because I have no idea what you are talking about
Posted: January 06, 2012 at 11:41 PM / IP Logged
The plug with the lock wires is called a quadlock, that fuse box is starting to lock like it came from Siemens in Germany.
chev104275
Gold - Posts: 1,436
Posted: January 07, 2012 at 5:53 AM / IP Logged
Ohh ok now I understand
Posted: January 07, 2012 at 6:31 AM / IP Logged
I was being stupid, probably managed to offend everyone of middle European origins. Just that I've never seen a quadlock on an oriental car before,solely European, having said that who knows what comes from where any more.
Half of the Kias and Hyundais come from Hungary!
mofabio
Posted: July 03, 2012 at 4:56 PM / IP Logged
Thank you chev104275 for your great job.
I want mount my alarm on my new sportage 2012.
Please, could you confir me the connection, trigger door and ACC?
this my alarm wiring diagram:
Trigger door is neg. or pos. ? color of wire?
ACC color wire? Use Acc1-Blue or Acc2-White?
Thanks in advance
Posted: July 03, 2012 at 5:07 PM / IP Logged
If you're in Italy throw away that alarm and use a Cobra or Metra, that alarm is a POS. Reason? You should never cut the fuel pump or ignition, only the starter wire and what do they mean by fuel sensor wire RX and TX?
Bet it's a Chinese alarm.
Page of 3
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
