06 chrysler sebring sedan
turbo-ef-hatch
Posted: December 17, 2007 at 8:49 PM / IP Logged
i would like to know what would be the best route to go installing a avital 4300 remote start in this car it has the immobilizer.which bypass would be the easiest to use and i only have one factory key so that leaves me with a minor problem as far as buying just any bypass box,and last is the door locks i want to know what i would need to get these hooked up as well?any info would be much appreciated-thanks!
tedmond
Gold - Posts: 4,610
Posted: December 18, 2007 at 4:06 PM / IP Logged
any idatalink or bypasskit would be best. now they offer door lock modules or just transponder bypass only.
the car uses a single wire to lock and unlock.
the wire is WHITE/ Dark Green (+) @ BCM Pin 15*
*BCM is located at the bottom of the fusebox on driver side. use connector 4 that is a 26 Pin plug.*
Lock (+) - across 2700 Ohm resistor
Unlock (+) - across 620 Ohm resistor
turbo-ef-hatch
Posted: December 22, 2007 at 4:09 PM / IP Logged
thanks for the info!
chriswallace187
Gold - Posts: 1,661
Posted: December 22, 2007 at 4:26 PM / IP Logged
No bypasskit or idatalink immobilizer bypass for a Chrysler, and for that matter none that I know of at all, can be programmed without 2 existing keys that will start the car. There are plenty of bypasses that don't use up the 2nd key, but they need 2 separate keys to program them to the car in the first place.
You'll have to get a 2nd key made if you want a remote start on the car. Most of the dealers around my area(Pittsburgh) have quoted me around $75 to cut and program a new Chrysler SentryKey...if you can find a locksmith who does them that may be even cheaper.
C Renner's Auto Electronix
