6.7l dodge high idle
saskpuller
Copper - Posts: 144
Posted: December 24, 2007 at 5:00 PM / IP Logged
Has anyone hooked up the high idle feature that is available on the6.7l diesel? From what I understand, you hit the cruise a couple times and the motor idles up to about 1000rpm. I have a couple customers that would like to do this.
aziegler
Member - Posts: 24
Posted: December 25, 2007 at 10:32 PM / IP Logged
Saskpuller,
I had it enabled on my 05 Ram 5.9. The dealer plugged in and enabled it in a couple key strokes.  While in park I turn on the cruze and hit set.  I can adjust the RPMs by using the increase/decrease speed buttons.
I;m not sure if this is the samr as yours, but I hope this helps.
AZ
saskpuller
Copper - Posts: 144
Posted: December 26, 2007 at 1:32 PM / IP Logged
Sure, the new trucks come with this enabled. I want to do this from the remote.
tonyberg
Copper - Posts: 116
Posted: December 26, 2007 at 4:48 PM / IP Logged
Its a bussed message from the steering column to the engine controller, I dont think that you will be able to reproduce that with an aftermarket remote system
tedmond
Gold - Posts: 4,610
Posted: December 26, 2007 at 7:56 PM / IP Logged
all new cars are data controlled. NO data interface module outhere would be able to do this.
