2007 trailblazer ls car starter
FrozenTundra
Member - Posts: 6
Posted: December 27, 2007 at 7:19 AM / IP Logged
Looking for the wire information on a 2007 trailblazer ls with factory remote keyless entry. Is it the same a a 2006?? Also I would like to hook up the locks so I only need on remote. Is there a specific module needed to interface the system?? I would rather not use a ton of relays if a module exists.
Twelvoltz
Platinum - Posts: 2,384
Posted: December 27, 2007 at 7:38 AM / IP Logged
Audiovox Lists:
          #510395: 2007 CHEVROLET TRAILBLAZER 4DR SUV WITH 5.3L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          ORANGE          (+)          RADIO HARNESS
     Accesory          ORANGE          (DATA)          RADIO HARNESS
               THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
     Ground          BLACK/ WHITE          (-)          RADIO HARNESS
     LF Speaker (+)          TAN
               THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
     LF Speaker (-)          GRAY
     RF Speaker (+)          LIGHT GREEN
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          DARK GREEN
     LR Speaker (+)          BROWN
     LR Speaker (-)          YELLOW
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          LIGHT BLUE
     Steering Cntrls          OPTIONAL
               THIS VEHICLE MAY BE EQUIPPED WITH ONSTARŪ AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES.
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          RED OR RED / WHITE          (+)          AT IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          AT IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          AT IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/BLACK          (-)          AT VEHICLE REAR FUSEBOX UNDER LEFT REAR SEAT
               TO AVOID THE DOMELIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE,
     Domelight Super          GRAY/BLACK          (+)          AT VEHICLE REAR FUSE BOX UNER REAR LEFT SEAT
     LF Latch          GRAY/BLACK          (-)          IN THE DRIVERS DOOR
     RF Latch          BLACK/ WHITE          (-)          IN THE PASSENGERS DOOR
     LR Latch          LIGHT BLUE/BLACK          (-)          IN THE PASSENGERS DOOR
     RR Latch          LIGHT GREEN/ BLACK          (-)          IN THE PASSENGERS DOOR
     Trunk Trigger          PINK/BLACK          (-)          AT MODULE IN REAR HATCH
               VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH
     Hood Trigger          PINK/BLACK          (-)          ON LEFT INNER FENDER
               NOT ON ALL MODELS
     Alarm Disarm          LT. GREEN          (-)          IN DRIVERS DOOR AT MODULE
     Parking Lights          GREY/BLACK          (-)          AT SWITCH
               OR BCM TAN PLUG PIN E5
     Low Crr Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Data Bus          VIOLET          (DATA)          AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
     Convenience
     Headlights-Lo          WHITE          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          BROWN          (+)          AT FRONT LEFT PARKING LAMP
     RF Pk Lt Bulb          BROWN          (+)          AT FRONT RIGHT PARKING LAMP
     LR Pk Lt Bulb          BROWN          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Pk Lt Bulb          BROWN / WHITE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     All Hazrd Lights          WHITE          (-)          AT VEHILCE HAZARD SWITCH
     LF Hazrd Bulb          LIGHT BLUE          (+)          AT FRONT LEFT TURN LAMP
     RF Hazrd Bulb          DARK BLUE          (+)          AT FRONT RIGHT TURN LAMP
     LR Hazrd Bulb          LIGHT BLUE          (+)          AT REAR LEFT TAIL LIGHT ASSEMBLY
     RR Hazrd Bulb          DARK BLUE          (+)          AT REAR RIGHT TAIL LIGHT ASSEMBLY
     Wipers-Lo          PINK          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          DARK BLUE          (-)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          LIGHT BLUE          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Seat Mem 1          WHITE          (+)          AT MODULE IN DRIVER DOOR
     Seat Mem 2          VIOLET          (+)          AT MODULE IN DRIVER DOOR
     Remote Start
     Ignition 2          WHITE          (+)          AT IGNITION SWITCH HARNESS
     Accessory 1          ORANGE          (+)          AT IGNITION SWITCH HARNESS
     Accessory 2          BROWN          (+)          AT IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSLOCK IIŪ ANTI-THEFT SYSTEM
     Anti-Theft Descript          PASSLOCK II
     Key Sense          LIGHT GREEN          (-)          AT THE STEERING COLUMN HARNESS
     Tachometer          UNCOMMON COLOR          (AC)          ANY FUEL INJECTOR NOT PINK
     Speed Sense          DK. GREEN / WHITE          (AC)          AT RADIO 24 PIN GREY PLUG
               OR PCM BLUE CONN. PIN 21
     Low Crr. Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Brake Lights          WHITE          (-)          AT BRAKE SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          LIGHT GREEN          (+)          AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT
     Horn          BLACK          (-)          BCM TAN CONN. PIN E12
               ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT
     Modules
     WIRE          LOCATION
     Module 1          BCM-ATTACHED TO THE REAR FUSE BLOCK, BENEATH THE LEFT REAR SEAT
     Module 2          ECM-NEAR THE LOWER LEFT FRONT OF THE ENGINE
     Module 3          PCM-MOUNTED TO THE UPPER LEFT OF THE ENGINE
     Module 4          EBCM- FRONT DRIVER SIDE FRAME RAIL
     Doorlocks/Windows
     Databus Wire          VIOLET          (DATA)          AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
     Power Unlock          DATA BUSS SYSTEM          (REV)          AT MOTOR IN DOORS
               THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER.
     PowerLock          DATA BUSS SYSTEM          (REV)          AT MOTOR IN DOORS
     Driver Mtr Unlock          TAN          (REV)          AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B2
     Driver Mtr Lock          GREY          (REV)          AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B3
     Pas Mtr Unlock          TAN          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          GREY          (REV)          AT MOTOR IN DOOR
     LF Window Up          DARK BLUE          (REV)          DRIVER DOOR MODULE
     LF Window Dn          BROWN          (REV)          DRIVER DOOR MODULE
     RF Window Up          LIGHT BLUE          (REV)          PASSENGER DOOR MODULE
     RF Window Dn          TAN          (REV)          PASSENGER DOOR MODULE
     LR Window Up          DARK BLUE          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     LR Window Dn          BROWN          (REV)          REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
     RR Window Up          DARK BLUE          (REV)          REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     RR Window Dn          BROWN          (REV)          RERA RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Pick up the
GMDL-BP it does door locks, and passlock II. Very simple to install.
FrozenTundra
Member - Posts: 6
Posted: December 27, 2007 at 9:00 AM / IP Logged
Thank you exactly what I was looking for!!!
Did you get that from a program or something like that??
Twelvoltz
Posted: December 27, 2007 at 9:03 AM / IP Logged
Audiovox lists their information for free. If you go here just fill out the form and it will give you access to their tech site. techservices.audiovox.com.
tedmond
Gold - Posts: 4,610
Posted: December 27, 2007 at 2:31 PM / IP Logged
or you can go to www.scytek.net and download their wiring wizard. call them and activate it.
