06 pt cruiser, remote start
malakai
Member - Posts: 33
Posted: January 01, 2008 at 10:28 PM / IP Logged
I'm working on a 2006 PT Cruiser. I'm installing a viper 791xv. I'm using a xk532 for the sentry/doorlock/door sense. I have to remote working up to a point. I can lock/unlock the doors. The door sense works (i.e. the alarm goes off if I open a door). The hatch release works.
I'm having a problem with the remote start part. When I attempt to remote start. The accessory comes on.( radio hvac) but it does not attempt to crank. When using the diagnostic from the alarm it says no or missing tach. I have learned the tach 2 times. It trys the normal 3 times and shuts down. I have tried the brown wire from the 532 connected to the blue wire on the ribbon cable between the xcrs and brain. I have also tried the second status output for a connection. I checked the brown wire for voltage and I'm getting 12v when not trying to start the car. I don't think this is the way it should be since the manual has it listed as a neg input.
Any questions or suggestions would be great
Thanks in advance.
Malakai
Chris Luongo
Platinum - Posts: 3,746
Posted: January 02, 2008 at 7:20 AM / IP Logged
How about the red dot on the dash, the security light? When trying to remote start, does it come on steady and go out, or is it flashing?
malakai
Member - Posts: 33
Posted: January 02, 2008 at 11:04 AM / IP Logged
I didn't check the light but I did place a key in the ign to make sure that the sentry was not the problem.
another-kelly
Silver - Posts: 618
Posted: January 02, 2008 at 8:03 PM / IP Logged
so it did start when you put a key in the ign? if so then did you program the RF portion of the xk532 to the vehicle?
malakai
Member - Posts: 33
Posted: January 02, 2008 at 8:32 PM / IP Logged
No it didn't start with key in ign. I went and asked the local audio shop and they had no suggestions.
malakai
Member - Posts: 33
Posted: January 03, 2008 at 12:24 PM / IP Logged
OK I have been going through my wiring here is the way I have it wired. Maybe someone can see an error that I have made..
From the 532
Red (+12v) straight from the battery
Black (ground) Ground point
Orange (trunk) to RED / White on Main 791 harness (2nd channel output)
Pink (Start Input) to Purple on Main 791 harness
Pink/White (Door Sense) to Green on Main 791 harness
Violet (data) to ORANGE / White Skim Plug in steering column
Violet/White (MUX) to Violet/Brown IGN harness
Blue (unlock) to blue on lock harness on 791
Green (lock) to green on Lock harness on 791
Brown (RS Activation) to Blue second harness on XRCS ( 2nd status output)
On the 791 I have
H1 main harness
RED / white (channel 2) to Orange 532 (trunk)
Red (+12v) to Battery
Brown(siren) to Siren
Black to Ground
Violet (+ door trigger) No connection
Blue (- trunk tigger0 no connection
Green (- Door trigger) to Pink/white 532 (Door Sense output)
BLACK/ White (Domelight) No connection
WHITE/ Blue (remote start activation ) NO connection
White (park lights) to WHITE/ violet Drivers Kick panel
Orange (ground when armed) No connection
H2 6 pin Harness is not used.
Door lock harness 3 pin
Blue connected to blue on 532 (unlock)
green connected to Green on 532 (lock)
Ribbon cable is connected
H3 5Pin
Blue/white (status/rear defrogger) No connection
Gray (hood pin) No connection (waiting on mecury switch)
Brown (Break shutdown) to GREEN / WHITE at brake switch
Violet/White (Tach) to Fuel injector Opposite of GREEN/ Orange
BLACK/ white (Neutral Safety) to Ground Point
Heavy Gauge Inline Connector
Purple to Pink/Blue Starter side Ign harness
Green to Pink/Blue Key side Ign harness
Red to Battery
Orange No Connection
Pink to Pink/White Ign Harness
Red to Battery
Pink/White to No Connection
RED / White to Battery
malakai
Member - Posts: 33
Posted: January 04, 2008 at 9:44 AM / IP Logged
no suggestions boys?
another-kelly
Silver - Posts: 618
Posted: January 06, 2008 at 6:01 PM / IP Logged
change it to voltage sense and and try to remote start. first without the key in the ignition. if that doesn't work then try with the key in the ignition
malakai
Member - Posts: 33
Posted: January 08, 2008 at 5:36 AM / IP Logged
Ok I tried.. No crank either way.  Any other suggestions?
another-kelly
Silver - Posts: 618
Posted: January 08, 2008 at 7:12 PM / IP Logged
shutdown diagnostics showed?
think you need to double and triple check all wiring and connections
