2005 nissan altima dei 451m
stx-di
Member - Posts: 19
Posted: January 07, 2008 at 2:33 PM / IP Logged
I am looking to install a DEI 451M to a nissan altima factory door locks. What wires connect where I don't have any prints on this relay pack.
Thanks,
Kurt
Twelvoltz
Platinum - Posts: 2,384
Posted: January 07, 2008 at 3:33 PM / IP Logged
What is the make and model of your after market system? Since your factory door locks are controlled by low current negative pulses you probably do not need the 451M in the 05 Altima.
stx-di
Member - Posts: 19
Posted: January 07, 2008 at 3:38 PM / IP Logged
Viper 771xv with remote start
Twelvoltz
Posted: January 07, 2008 at 3:41 PM / IP Logged
No need to use the 451M....your unit offers negative pulse outputs for door locks.
Here is what Audiovox lists:
          #506757: 2005 NISSAN ALTIMA 4DR SEDAN WITH 2.5L ENGINE AND BOSE® AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          YELLOW /GREEN          (+)          RADIO HARNESS
     Accesory          PURPLE          (+)          RADIO HARNESS
     Ground          CHASSIS          (-)          CHASSIS GROUND
               THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS.
     Illumination          RED / BLUE          (+)          RADIO HARNESS
     Dimmer          RED / YELLOW          (+)          RADIO HARNESS
     Power Antenna          GREEN          (+)          RADIO HARNESS
     Amp Turn On          GREEN / WHITE          (+)          RADIO HARNESS
     LF Speaker (+)          BLUE/WHITE
     LF Speaker (-)          BLUE/RED
     RF Speaker (+)          WHITE/ BLACK
     RF Speaker (-)          BLUE/BLACK
     LR Speaker (+)          GREEN/ YELLOW
     LR Speaker (-)          BLACK / YELLOW
     RR Speaker (+)          BLUE
     RR Speaker (-)          RED
     Amp Location          UNDER REAR DECK IN TRUNK
     Steering Cntrls          YES
     Speed Cntrl          YES
     Radio Security          YES
     Security
     Battery          GREEN          (+)          AT IGNITION HARNESS
     Ignition 1          BLACK/ RED          (+)          AT IGNITION HARNESS
     Starter 1          BLACK/ RED          (+)          AT IGNITION HARNESS
     All Door Trigger          USE LATCH WIRES          (-)          DIODE ISOLATE
               PIN #32
     Domelight Super          RED          (-)          BCM PIN 63
               PIN #63
     LF Latch          LIGHT BLUE          (-)          BCM PIN 47
               WHEN INSTALLING A REMOTE START IN AN ALTIMA WITH AUTO-HEALIGHTS, YOU MUST PULSE THIS WIRE GROUND WHEN THE REMOTE START SHUTS DOWN TO KEEP THE HEADLIGHTS FROM STAYING ON.
     RF Latch          PINK/BLUE          (-)          BCM PIN 12
               PIN #12
     LR Latch          RED / BLACK          (-)          BCM PIN 48
               PIN #48
     RR Latch          RED / WHITE          (-)          BCM PIN 13
               PIN #13
     Trunk Trigger          PURPLE / WHITE          (-)          BCM PIN 42
               PIN #42
     Hood Trigger          YELLOW/BLACK          (-)          AT POWER DISTRIBUTION CENTER UNDER HOOD
     Alarm Disarm          WHITE/ BLUE          (-)          IN THE DRIVERS DOOR AT DOOR MODULE PIN 4
               SINGLE PULSE WILL DISARM THE ALARM AND A DOUBLE PULSE WILL UNLOCK THE DOORS.
     Alarm Arm          PINK/BLUE          (-)          IN THE DRIVERS DOOR AT DOOR MODULE PIN 5
               PIN #59 - THIS WIRE RESTS AT +5V, USE A RELAY TO PULSE THIS WIRE TO PREVENT A +12V SIGNAL FROM BEING APPLIED BY SOME ALARM OR KEYLESS ENTRY SYSTEMS.
     Parking Lights          RED / BLUE          (+)          DRIVERS SILL PLATE
               ALSO AT DIMMER SWITCH LEFT SIDE OF STEERING COLIMN ON DASH.
     Convenience
     Headlights-Lo          BLUE (LEFT), RED / YELLOW (RIGHT)          (+)          GRAY 16 PIN CONNECTOR AT IPDM E/R
               PIN #24 & #22 - USE BOTH WIRES AND DIODE ISOLATE THEM.
     Headlights-Hi          BLUE/WHITE & GREEN          (+)          AT POWER DISTRIBUTION CENTER UNDER HOOD
               PIN #21 & #27 - USE BOTH WIRES AND DIODE ISOLATE THEM.
     LF Pk Lt Bulb          RED / BLUE          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          RED / BLUE          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          RED / BLUE          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          RED / BLUE          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          GREEN/ RED          (-)          BCM PIN 29
               PIN #29
     LF Hazrd Bulb          GREEN/ BLACK          (+)          AT FRONT LEFT DIRECTIONAL LIGHT
               WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #22
     RF Hazrd Bulb          GREEN/ YELLOW          (+)          AT FRONT RIGHT DIRECTIONAL LIGHT
               WILL ALSO BE FOUND AT BCM MODULE BEHIND LEFT SIDE OF DASH NEAR FUSE PANEL - PIN #21
     LR Hazrd Bulb          GREEN/ BLACK          (+)          AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb          GREEN/ YELLOW          (+)          AT REAR RIGHT DIRECTIONAL LIGHT
     Wipers-Lo          BLUE          (+)          GRAY 16 PIN CONNECTOR AT IPDM E/R
               PIN #31
     Wipers-Hi          BLUE/BLACK          (+)          GRAY 16 PIN CONNECTOR AT IPDM E/R
               PIN #30
     Parking Brake          GREEN          (-)          AT PARKING BRAKE SWITCH
     Trnk Release          RED / BLACK          (-)          BCM PIN 30
               MAY ALSO BE BLUE/RED
     Remote Start
     Ignition 2          BLACK/ RED          (+)          IGNITION SWITCH HARNESS
     Accessory 1          RED          (+)          AT IGNITION HARNESS
     Accessory 2          WHITE/ BLUE          (+)          AT IGNITION HARNESS
     Starter 2          BLACK / YELLOW          (+)          AT IGNITION HARNESS
     Anti-Theft Type          NISSAN NVIS® VEHICLE IMMOBILIZER
     Anti-Theft Descript          TRANSPONDER
     Key Sense          BLACK/ RED          (-)          AT IGNITION HARNESS
               ALSO AT BCM PIN 37
     Neutral Safety          GREEN/ RED          (-)          AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
               PIN #43 - WILL BE GREEN/ RED ON AUTOMATIC TRANSMISSION MODELS AND GREEN / WHITE ON MANUAL TRANSMISSION MODELS.
     Tachometer          USE INJECTOR OR COIL          (AC)          USE UNCOMMON WIRE ON ANY COIL OR INJECTOR
               THE VEHICLE TACHOMETER SIGNAL IS SENT THROUGH A DATABUS LINE - YOU MUST USE A CRANKSHAFT OR CAMSHAFT POSITION SENSOR OR A FUEL INJECTOR SIGNAL WIRE.
     Crankshaft Sensor          WHITE          (AC)          AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
               PIN #71
     Camshaft Sensor          WHITE          (AC)          AT ECM MODULE BEHIND GLOVEBOX ABOVE PASSENGER FOOTWELL
               PIN #62
     Speed Sense          PINK          (AC)          AT THE RADIO HARNESS
               MAY ALSO BE BLACK. THIS IS ON THE MIDLINE AND BOSE RADIO VEHICLES ONLY. VEHICLES WITHOUT 5 SPEED AUTOMATIC TRANSMISSION CAN USE A BLUE / YELLOW BEHIND INSTRUMENT CLUSTER.
     Brake Lights          RED / GREEN          (+)          AT BRAKE SWITCH
     Reverse Lights          GREEN / WHITE          (+)          DRIVERS SILL PLATE
     Horn          GREEN / WHITE          (-)          AT STEERING COLUMN HARNESS
     Anti Theft RX          BLUE/RED          (DATA)          AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN
     Anti Theft TX          WHITE/ BLUE          (+)          AT IMMOBILIZER CONTROL UNIT IN STEERING COLUMN
     Modules
     WIRE          LOCATION
     Module 1          BCM IS LOCATED TO THE RIGHT OF THE FUSE BOX
     Module 2          IPDM E/R (INTELLIGENT POWER DISTRIBUTION MODULE ENGINE ROOM) IS UNDER HOOD BEHIND PASSENGERS HEADLIGHT.
     Doorlocks/Windows
     Power Unlock          PINK          (-)          BCM PIN 46
               THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK.
     PowerLock          BROWN          (-)          BCM PIN 45
               TEST WITH THE KEY IN THE DRIVERS DOOR. THIS WIRE IS USED FOR VEHICLES WITH LEFT FRONT ANTI PINCH SYSTEM ONLY. ON VEHICLES WIYH BOTH FRONT WINDOW ANTI PINCH USE FACTORY ARM/DISARM WIRES FOR LOCK/UNLOCK.
     Driver Mtr Unlock          GREEN/ RED          (REV)          BCM PIN 66
     Driver Mtr Lock          YELLOW/RED          (REV)          BCM PIN 65
     Pas Mtr Unlock          GREEN / WHITE          (REV)          BCM PIN 59
     LF Window Up          BLUE/RED          (REV)          AT DRIVERS WINDOW SWITCH IN DOOR
     LF Window Dn          BLUE/WHITE          (REV)          AT DRIVERS WINDOW SWITCH IN DOOR
     RF Window Up          GREEN          (REV)          DRIVERS KICK PANEL
               IF VEHICLE HAS AUTO UP/DOWN ON PASSENGERS FRONT WINDOW YOU MUST USE BLUE FOR UP AND GREEN/ BLACK FOR DOWN IN THE PASSENGERS DOOR.
     RF Window Dn          YELLOW          (REV)          DRIVERS KICK PANEL
     LR Window Up          PURPLE          (REV)          DRIVERS KICK PANEL
     LR Window Dn          BLUE          (REV)          DRIVERS KICK PANEL
     RR Window Up          RED / YELLOW          (REV)          DRIVERS KICK PANEL
     RR Window Dn          YELLOW/BLACK          (REV)          DRIVERS KICK PANEL
     Sunroof Open          ORANGE          (+)          AT SUNROOF SWITCH
               THIS WIRE WILL EITHER CLOSE THE VENT POSITION OR SLIDE THE SUNROOF OPEN DEPENDING ON THE CURRENT STATE OF THE ROOF.
     Sunroof Close          BLUE/RED          (+)          AT SUNROOF SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
stx-di
Member - Posts: 19
Posted: January 07, 2008 at 4:52 PM / IP Logged
Thanks for the help
Kurt
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
