02 toyota sienna door locks
bat9905
Copper - Posts: 131
Posted: January 13, 2008 at 9:28 PM / IP Logged
Hello I was wondering if any body could help me. I have a 2002 toyota sienna van and a prestige remote start keyless entry and the diagram says door lock wires are in passenger kick panel with lock being blue w white and unlock being blue with yellow. Is the unlock wire a bigger gauge wire because that is the only wire in the door lock wiring harness? I can get the doors to lock but not unlock
bat9905
519civiconair
Copper - Posts: 50
Posted: January 14, 2008 at 4:18 AM / IP Logged
Have you tried probing the "suspect" wire with a DMM and hitting the unlock button?? Did you get a reading? if not keep looking.... if you did then.......
F.B.S.S air ride is the only way to roll
KarTuneMan
Platinum - Posts: 7,056
Posted: January 14, 2008 at 8:57 AM / IP Logged
Look up higher in the kick. Abou5t as high as the ebrake pedal. Use the key in the door to test, not the switch.
Lock and arm is blue/white.Disarm is blue. set up with double pulse.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 14, 2008 at 10:25 AM / IP Logged
Just did one yesterday, and you can get them in the driver's kick panel, coming in from the door.
bat9905
Copper - Posts: 131
Posted: January 16, 2008 at 7:03 PM / IP Logged
Thanks for the help i found them and everything worked
bat9905
