96 outback keyless, remote start
subydoo
Member - Posts: 11
Posted: January 17, 2008 at 5:30 PM / IP Logged
I have a 96 Subaru Outback that has factory power locks, no switch just open from lock lever and all other doors unlock, key does the same from outside. I want to install a keyless entry system and a remote start system while I am at it.
What do I need to know, I think I have found enough wiring diagrams to figure where everything plugs in. I have heard that I may need an actuator installed in the passenger side door. I am not sure what that would do, it seems that all doors already unlock with the power locks already.
I would like to get the parking lights to flash and turn on the dome light when the car is unlocked, in addition to simply unlocking the doors and starting the car.
What kind of lock mechanisms do I have? Do I need to do anything else to get ready, or can I just buy a decent aftermarket system and start running wires.
I have looke under the dash, I do not have the factory keyless entry system installed.
Any help in the way of tips, diagrams, and or recommendations on different systems would be great.
I have a copy of the factory keyless entry install instructions, but it does not do remote start.
mikvot
Gold - Posts: 1,043
Posted: January 17, 2008 at 6:18 PM / IP Logged
You will need to install an actuator in the drivers door, not the passenger.  You will need a couple of relays to control the actuator. you can find a diagram for the actuator in the relay section at the top of the page. For the park light and dome light, any good system will have these features.
Wire/Function Colour Location/Description Polarity
 12 VOLTS BLACK / YELLOW Ignition harness   +
 IGNITION Red Ignition harness   +
 ACCESSORY RED / yellow Ignition harness   +
 STARTER Blue/red Ignition harness   +
 KEY SENSE Yellow or BLACK / YELLOW Ignition harness   +
 TACH SIGNAL Blue Coil module
 LOCK WHITE/ red White plug in driver's kick   -
 MAY NOT HAVE DOORLOCK ACTUATOR IN DOOR, IF SO ONE WILL NEED TO BE INSTALLED. TEST BY TURNING KEY IN PASSENGER DOOR.
 UNLOCK White White plug in driver's kick   -
 DOORPIN RED / white In blue plug high up in DKP   -
 TRUNK PIN Common with doorpin
 TRUNK RELEASE Manual release
 FACTORY ARM GREEN/ YELLOW Driver's kick   -
 FACTORY DISARM WHITE/ green Driver's kick   -
 BRAKESWITCH WHITE/ black At switch above brake pedal   +
 PARKLIGHTS RED / green On steering column   -
 HAND BRAKE YELLOW /GREEN At handbrake or behind instrument panel   -
 HORN RED / green At steering column   -
 DRIVER WINDOW UP Blue/red At main window switch   REV POL
 DRIVER WINDOW DOWN Blue At main window switch   REV POL
 PASSENGER WINDOW UP WHITE/ green At main window switch   REV POL
 PASSENGER WINDOW DOWN White At main window switch   REV POL
 LEFT REAR WINDOW UP WHITE/ red At main window switch   REV POL
 LEFT REAR WINDOW DOWN WHITE/ red At main window switch   REV POL
 RIGHT REAR WINDOW UP WHITE/ blue At main window switch   REV POL
 RIGHT REAR WINDOW DOWN WHITE/ blue At main window switch   REV POL
 HEADLIGHTS Blue/black At light switch harness   -
 REVERSE LIGHTS Brown or BROWN / yellow In driver's kickpanel   +
 DIMMER Yellow/blue At any illuminated dash switch
 VSS WIRE GREEN/ black At ECM in passenger kickpanel
subydoo
Member - Posts: 11
Posted: January 17, 2008 at 7:00 PM / IP Logged
what is the deal with the actuator, is there not one involved in the factory power lock set up. I have not messed with locks yet, so i dont know that i understand what the actuator would do for me.
lostissues
Copper - Posts: 103
Posted: January 17, 2008 at 7:50 PM / IP Logged
subydoo wrote:
what is the deal with the actuator, is there not one involved in the factory power lock set up. I have not messed with locks yet, so I don’t know that I understand what the actuator would do for me.
you need an actuator due to the fact that you have manual door locks, now even though it does unlock the other doors when you press on the drivers lock/unlock, it isn’t the same as most cars with electric locks, I believe this is referred to as a central locking system but I may be wrong. Because you have to physically move the lock and there is not a switch that produces an electrical pulse that the car translates into locking and unlocking the doors, you have to add an actuator. The actuator will physically move the rods connected to the locks and in turn it would mimic you moving the lock/unlock lever. When you wire up the actuators try to get your hands on a DEI 451M.
Hope this helps,
Jonathan
subydoo
Member - Posts: 11
Posted: January 18, 2008 at 12:58 PM / IP Logged
Thanks for the info.
So it sounds like i need a keyless kit, an actuator and some relays. can anyone recommend good kits for cheap. I want to install myself, like the challenge, and am interested only in the keyless entry and remote start.
A kit that comes with good instructions would be nice and what about the actuator, where do i get one of those?
subydoo
Member - Posts: 11
Posted: February 13, 2008 at 1:14 PM / IP Logged
So I installed a viper 550 esp into my 96 suabaru legacy outback, went pretty smooth, thing works well. I only installed the keyless entry and remote start systems. I went ahead and removed the rest of the unneeded wires from the harnesses. I did ground one of the door trigger wires so I could get in and out of valet mode.
Anyway, is there any whay to get the system to not arm, other than valet mode, when i lock it with the clicker. because if i lock it with the clicker, then unlock it with the key, once i get the key in the ignition, the alarm sequence occurs. No siren but flashing lights and clicking relays under the dash.
I like the flashing LED, so i dont want it to be in valet mode all the time. and what is it that is triggering the alarm, I assume it is coming from the ignition, because there are no door wires hooked up except the keyless entry leads, and the one door wire grounded. Can i unhook something, or ground something or wire something up that will cause the arming of the unit to be bypassed or turned off.
I know thats long, but just trying to dial this thing in for the wife.
Let me know if i can provide more info
subydoo
Member - Posts: 11
Posted: February 14, 2008 at 9:19 PM / IP Logged
Anybody,
theres got to be a way to keep the brain from thinking the alarm sequence needs to be run. So I can just start the car, and unlock, lock the doors.
