2003 Ford F-250 Super Duty Diesel Alarm/RS Wiring
winfred
Member - Posts: 22
Posted: January 17, 2008 at 5:44 PM / IP Logged
I am looking for the wiring diagram for the 2003 Ford F250 Diesel. The one on this site gives infomation for the Super Duty Heavy and Light but not the actual F250/350 Diesel. Thanks for any help
Image is Everything
Platinum - Posts: 13,726
Posted: January 17, 2008 at 6:08 PM / IP Logged
They have info here 2004 but I do not know if it is for the diesel   https://www.the12volt.com/installbay/forum_posts.asp~TID~28999
KarTuneMan
Platinum - Posts: 7,056
Posted: January 17, 2008 at 6:51 PM / IP Logged
12 VOLTS Yellow Ignition harness   +
 IGNITION RED / green Ignition harness   +
 IGNITION 2 Blue/green
 This wire is only required on the V-10 Gas engine.
 ACCESSORY RED / black Ignition harness   +
 ACCESSORY 2 Gray / YELLOW Ignition harness   +
 STARTER Dk.green Ignition harness   +
 KEY SENSE BLACK/ pink In airbag plug on right side of st. column   -
 TACH SIGNAL Use an injector
 DIESEL TACH SIGNAL GREEN / WHITE SEE NOTES
 Look below the relay box under the dash for a large loomed harness. There are some wires taped to the harness terminated with heat shrink tubing. You will find the GREEN / WHITE among these wires.
 LOCK WHITE/ red In harness above gas pedal   +
 On 4 door models, these wire are negative trigger. Vehicles with no keyless entry, colors are Pink / YELLOW for lock and Pink/green for unlock in 5-wire reverse polarity. They will be found in either kickpanel.
 UNLOCK BLACK/ white In harness above gas pedal   +
 DRIVER LOCK MOTOR Pink/black In harness above gas pedal   +
 DRIVER UNLOCK MOTOR RED / orange In harness above gas pedal   +
 PASSENGER UNLOCK MOTOR Pink/orange In harness above gas pedal   +
 GLO-PLUG SIGNAL DATA ONLY USE DELAY TIMER
 DOORPIN BLACK/ blue Above parking brake in DKP   +
 The vehicle’s computer sends out diagnostic pulses on this wire every 15-20 minutes. This may cause an after-market alarm to false. It is suggested that you add a relay to this wire when connecting to an alarm system. See the appropriate diagram for exact wiring instructions.
 FACTORY ARM Yellow/black Above parking brake in DKP   -
 This is the driver’s doorpin wire. Pulse this wire at the same time as lock to arm the factory alarm.
 FACTORY DISARM Dk.GREEN/ purple In harness above gas pedal   -
 BRAKESWITCH Green At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   +
winfred
Member - Posts: 22
Posted: January 17, 2008 at 8:23 PM / IP Logged
Thank you for your assistance, greatly appreciated.
Image is Everything
ralphtonka
Member - Posts: 30
Posted: January 17, 2008 at 11:01 PM / IP Logged
for glow plug (think its +) pull cluster and solder onto top side of wait to start led, labled wait to start on cct board
