xk01 amdl programming
baypoint
Member - Posts: 7
Posted: January 20, 2008 at 1:21 PM / IP Logged
I am having trouble programming XK01, the led lights, I turn the key to on but the led won't flash it  just stays on steady. Any suggestions?
chadwa2003
Copper - Posts: 353
Posted: January 20, 2008 at 3:15 PM / IP Logged
What kind of vehicle is it? Did you hook up the ignition input?
GregK
Copper - Posts: 74
Posted: January 20, 2008 at 3:45 PM / IP Logged
Is it connected D2D or W2W?
Did you connect to the correct ODBII wire?
More details would be great, year, make and mpodel of vehicle and the RS unit you're hooking up.
GDK Electronics
Home theatre & mobile electronics installations
Winnipeg, MB
baypoint
Member - Posts: 7
Posted: January 20, 2008 at 4:06 PM / IP Logged
05 Jeep Liberty  Audiovox APS997 w2w
Brown to RS ground when running
Green to RS red lock
Blue to RS green unlock
violet/white to RS brown door trigger
violet to ODBII pin 2 w/violet
pink/white n/c
pink n/c
orange to RS dk blue trunk
red to 12v
black to ground
GregK
Copper - Posts: 74
Posted: January 20, 2008 at 4:56 PM / IP Logged
Did you manage to get the module programmed to type 7 for your Jeep first?
If so, turn the ignition on, the LED will remain lit, start the vehicle with the key and you should see the LED flash green.
If it does, it's now programmed.
If that doesn't work try resetting the module.
Unplug the 10 pin harness, hold the programming button in and plug the harness back in. Release the button when the LED flashes.
Program the unit to type 7 for your Jeep.
Start the vehicle with the key
You shouldn't have to change any mode options for your vehicle.
GDK Electronics
Winnipeg, MB
baypoint
Member - Posts: 7
Posted: January 20, 2008 at 5:56 PM / IP Logged
I tried starting and the LED stayed red, also tried to reset but when I hold the button in the LED never flashes. Maybe bad module?
GregK
Copper - Posts: 74
Posted: January 20, 2008 at 6:03 PM / IP Logged
Maybe it is a bad module. Which firmware is on it? Make sure it's AMDL 6.00
GDK Electronics
Winnipeg, MB
baypoint
Member - Posts: 7
Posted: January 20, 2008 at 6:08 PM / IP Logged
amdl 6.0
GregK
Copper - Posts: 74
Posted: January 20, 2008 at 6:26 PM / IP Logged
I would say bad module if you're 100% sure all of your wiring connections are good.
GDK Electronics
Winnipeg, MB
robertsc
Copper - Posts: 337
Posted: January 20, 2008 at 8:18 PM / IP Logged
I.
i think your thinking of an idatalink  module
i have only seen red led's on bypasskits modules
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
