1996 jetta alarm wiring
over_boost
Member - Posts: 16
Posted: January 30, 2008 at 1:47 PM / IP Logged
hi guys, i was just wondering if i can connect the arm and disarm wire to the lock and unlock relay? they both have a positive trigger. Disarm would require a single pulse and unlock would require a double pulse.
Thank you.
audioman2007
Copper - Posts: 580
Posted: January 30, 2008 at 2:36 PM / IP Logged
That is correct BUT if your alarm can be programed for double pulse, then you wont need a relay
over_boost
Member - Posts: 16
Posted: January 30, 2008 at 2:37 PM / IP Logged
Hi guys i have a 5 speed Jetta, i have found most of the wires, i just need to know where i can get the wire for the parking brake and the polarity of it.
Thank you.
over_boost
Member - Posts: 16
Posted: January 30, 2008 at 3:14 PM / IP Logged
oh ok , but the alarms output is a (-) and the vehicle lock is (+)
audioman2007
Copper - Posts: 580
Posted: January 30, 2008 at 3:15 PM / IP Logged
use a relay to convert the polarity.
over_boost
Member - Posts: 16
Posted: January 30, 2008 at 3:22 PM / IP Logged
sounds good, thanks for the info.
over_boost
Member - Posts: 16
Posted: January 30, 2008 at 3:27 PM / IP Logged
hey, does anyone know the location of the hand brake wire is? and what is the polarity on it?
audioman2007
Copper - Posts: 580
Posted: January 30, 2008 at 5:22 PM / IP Logged
What would you need that wire for?
flobee4
Silver - Posts: 585
Posted: January 31, 2008 at 12:18 AM / IP Logged
parking brake:  BROWN / Yellow (-) at relay 173, on the back side of the relay bank.
tedmond
Gold - Posts: 4,610
Posted: January 31, 2008 at 6:48 AM / IP Logged
are you installing a remote start? or an alarm? because i havent seen an alarm that asks for a handbrake connection.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
