06 pontiac g6 ads dlsl gm?
bruc007
Copper - Posts: 74
Posted: January 30, 2008 at 6:43 PM / IP Logged
Hey guys ,I've got a 06 g6 gt to do this weekend and waswondering if anyone has used this bypass and are there areany tips I should know about its operation..It's the first dual security vehicle Ive done.This kit seems to be able to do it all.Use this site and navigate to the year and make to see the kit.
Thanks Bruce
http://www.idatalink.com/prostart/ http://www.idatalink.com/prostart/
Moderator - Posts: 12,488
Posted: January 30, 2008 at 6:49 PM / IP Logged
The module works great on all the PK3+ systems. Integrates flawlessly for door locks, trunk release, door triggers and bypass.
bruc007
Copper - Posts: 74
Posted: January 30, 2008 at 6:55 PM / IP Logged
Thanks Jeff, A couple of questions, in the manual the tach output wire is red and the instructions are hazy.Is this a good tach source?Or is it even usable.Does the RAP wire have to be hooked up to this vehicle?
Thanks again,Bruce
StealthEs
Copper - Posts: 326
Posted: January 30, 2008 at 6:57 PM / IP Logged
looks very straight forward. shouldn't be anything to hard. Almost like the Nissans where you need to interrupt the security light. I've used a ton of Idatalink module for different car haven't had any problems aside from note fully read the directions.
Cris
StealthEs
Copper - Posts: 326
Posted: January 30, 2008 at 6:59 PM / IP Logged
If you alarm is capable of doing the 2way through the Idatalink you dont need to hook it up, if not just hook it up to the tach wire on the remote start unit.
Cris
StealthEs
Copper - Posts: 326
Posted: January 30, 2008 at 7:01 PM / IP Logged
AS far as for the RAP system that would again fall into if your unit is 2way capable if not just follow these notes. A rap shutdown (-) output, with thePURPLE / black wire connected to ground. The greenwire must be connected to the driver door switchto turn off radio at the end of the remote startsequence.These would be off the Idatalink module.
Cris
bruc007
Copper - Posts: 74
Posted: January 30, 2008 at 7:02 PM / IP Logged
it does have the idatalink.so that also looks after the tach ..neat
StealthEs
Copper - Posts: 326
Posted: January 30, 2008 at 7:03 PM / IP Logged
Yes then you should be set. I would also have the tach wire from the module just in case.
Cris
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
