valet 712t factory alarm ouput
jdebuhr
Posted: February 02, 2008 at 5:45 PM / IP Logged
Hi all,
I have installed a couple alarms/keyless entry systems in the past but this one has me stumped
in the install manual it explains all of the outputs/inputs to the alarm, btu when I get to the info on the Factory Disarm wire I get this:
H1/13 LT. GREEN/ BLACK Factory Alarm Disarm
This wire supplies a
nothing after that. I searched here, found a couple posts with links to the same manual, with the same explanation. I am hoping it is a grounding signal, but have not tried it yet, i was hoping someone her ran into this issue
Mike M2
Platinum - Posts: 2,652
Posted: February 02, 2008 at 5:48 PM / IP Logged
Funny, this is a wire i'm dealing with right now. It is a negative pulse before start and also during disarm.
Mike M2
Tech Manager
CS Dealer Services
jdebuhr
Posted: February 02, 2008 at 5:54 PM / IP Logged
COOL Thanks!! that is what I was hoping for.. I will finish up the install tonight.
jdebuhr
Posted: February 02, 2008 at 8:24 PM / IP Logged
Got that working now neither of the AUX outputs ground when pressed.. Any thoughts? or is the unit bad?
