Car Alarm Wiring
Rotax100uk
Posted: February 28, 2003 at 1:03 PM / IP Logged
I have got hold of Rapid 100 alarm and i have got to have a wire which goes into the fuse box. but i need to know where in the fuse box it has got to go.on this site it says into a source which has a 12V DC current when in the RUN and START positionWhere in the fuse box would that be?
Rotax100uk
jrilla
Gold - Posts: 1,498
Posted: February 28, 2003 at 1:38 PM / IP Logged
That is just an Ignition wire that you can find coming from the key cylinder that typically runs down the steering column. That is also where you will find your 12v constant power source. Let us know what car you have and we can get you a wire diagram for your car.
J Rilla
Owner/Installer
Rotax100uk
Posted: February 28, 2003 at 2:02 PM / IP Logged
Peugeot 306
Year:- 1998
Rotax100uk
jrilla
Gold - Posts: 1,498
Posted: February 28, 2003 at 2:38 PM / IP Logged
I dont have much info on that car and the wire colors change from year to year. I do not have the wire diagram for a '98 306, but I have a '97 diesel, and a '96 306, and everyone is different. Look in the main ignition wire harness and let us know what you find. The colors I show as possibilities for Ignition are typically Yellow and an occasional Orange. For the starter wire it could be either blue or white. Sorry I can be of more help.
J Rilla
Owner/Installer
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
