2008 Chrysler 300 Alarm/Remote Start/Stereo Wiring
stevet
Member - Posts: 36
Posted: February 12, 2008 at 2:04 AM / IP Logged
Anyone have any info on wiring??? Installing an alarm (No remote start) anything would be helpful.
Twelvoltz
Platinum - Posts: 2,384
Posted: February 12, 2008 at 6:24 AM / IP Logged
Audiovox lists:
          #513911: 2008 CHRYSLER 300 4DR SEDAN WITH 2.7L ENGINE AND 4-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          GRAY/LIGHT GREEN          (+)          RADIO HARNESS
     Accesory
               THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
     Ground          BLACK/ LIGHT GREEN          (-)          RADIO HARNESS
     LF Speaker (+)          GRAY/VIOLET
     LF Speaker (-)          GRAY / YELLOW
     RF Speaker (+)          DARK GREEN/ VIOLET
     RF Speaker (-)          DARK GREEN/ YELLOW
     LR Speaker (+)          DARK GREEN/ TAN
     LR Speaker (-)          DARK GREEN/ GRAY
     RR Speaker (+)          DARK GREEN/ BROWN
     RR Speaker (-)          YELLOW/GRAY
     Steering Cntrls          OPTIONAL
     Speed Cntrl          OPTIONAL
     Radio Security          YES
     Security
     Battery          LIGHT BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK/WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 1          PINK/DARK GREEN          (+)          IGNITION SWITCH HARNESS
               NOT FOR REMOTE START
     All Door Trigger          YELLOW/WHITE          (+)          IN HARNESS IN PASSENGER SIDE WINDSHIELD PILLAR
               TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DOUBLE DIODE ISOLATE EACH WIRE
     LF Latch          VIOLET          (-)          IN HARNESS IN DRIVER KICKPANEL
     RF Latch          VIOLET/WHITE          (-)          IN HARNESS IN PASSENGER KICKPANEL
     LR Latch          VIOLET/GRAY          (-)          IN HARNESS IN DRIVER KICKPANEL
     RR Latch          VIOLET / YELLOW          (-)          IN HARNESS IN PASSENGER KICKPANEL
     Trunk Trigger          VIOLET/ORANGE          (-)          IN HARNESS IN PASSENGER KICKPANEL
     Parking Lights          WHITE/ VIOLET          (+)          IN HARNESS IN PASSENGER KICKPANEL
               USE A 1.6K OHM RESISTOR
     Low Crr Pk Lights          WHITE/ BROWN          (-)          AT VEHICLE HEADLIGHT SWITCH
               (-) THROUGH 1.6K OHM RESISTOR, MUST ISOLATE FROM SWITCH WITH RELAY
     Convenience
     Headlights-Lo          WHITE/ BROWN          (-)          AT VEHICLE HEADLIGHT SWITCH
               (-) THROUGH 1.2K OHM RESISTOR, MUST ISOLATE FROM SWITCH WITH A RELAY
     All Hazrd Lights          WHITE/ DARK BLUE          (-)          AT VEHICLE HAZARD SWITCH
     Wipers-Lo          BROWN / WHITE          (+)          AT VEHICLE WIPER MOTOR
     Wipers-Hi          BROWN / ORANGE          (+)          AT VEHICLE WIPER MOTOR
     Parking Brake          GRAY/BLACK          (-)          AT VEHICLE PARKING BRAKE SWITCH
     Trnk Release          VIOLET/TAN          (-)          AT TRUNK RELEASE SWITCH
     Remote Start
     Accessory 1          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               (-) THROUGH 610 OHM RESISTOR
     Starter 2          VIOLET/BROWN          (-)          IGNITION SWITCH HARNESS
               (-) THROUGH 180 OHM RESISTOR
     Anti-Theft Type          DAIMLER SENTRY KEY® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Speed Sense          DARK GREEN/ BROWN          (AC)          AT PCM MODULE ON PASSENGER FENDER UNDER HOOD
     Low Crr. Pk Lights          WHITE/ BROWN          (-)          AT VEHICLE HEADLIGHT SWITCH
     Brake Lights          GREEN / WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ LIGHT GREEN          (+)          IN HARNESS IN PASSENGER KICKPANEL
     Horn          DARK GREEN/ ORANGE          (+)          IN HARNESS AT VEHICLE HORN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          VIOLET/LIGHT GREEN          (-)          IN PLUG TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
               USE 100 OHM RESISTOR
     PowerLock          VIOLET/LIGHT GREEN          (-)          IN PLUG TO LEFT OF STEERING COLUMN BEHIND DRIVERS SIDE OF DASH
               USE 330 OHM RESISTOR
     LF Window Up          ORANGE / WHITE          (AC)          AT DRIVER WINDOW SWITCH
               MAY ALSO BE ORANGE / LIGHT BLUE
     LF Window Dn          ORANGE / LIGHT GREEN          (AC)          AT DRIVER WINDOW SWITCH
               MAY ALSO BE ORANGE DARK BLUE
     RF Window Up          ORANGE / GRAY          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
               MAY ALSO BE DARK BLUE/ORANGE
     RF Window Dn          ORANGE / TAN          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
               MAY ALSO BE LIGHT GREEN/ ORANGE
     LR Window Up          ORANGE / GRAY          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn          ORANGE / WHITE          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up          ORANGE / DARK BLUE          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn          ORANGE / LIGHT BLUE          (AC)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Sunroof Open          ORANGE / TAN
     Sunroof Close          ORANGE / LIGHT BLUE
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
hydroz_23
Copper - Posts: 97
Posted: February 12, 2008 at 8:48 AM / IP Logged
08 is different
stevet
Member - Posts: 36
Posted: February 13, 2008 at 1:54 PM / IP Logged
It is different, there is no starter wire. Anyone else with any info?????????
tedmond
Gold - Posts: 4,610
Posted: February 13, 2008 at 2:37 PM / IP Logged
i havent done a chrysler 300 yet, but the ignition system has something called a Multiplex system. There are ignition and Acc wires. When you turn the key, Acc drops and becomes a Starter wire. You should use bypass modules that can interface these wires or using 2 relays, it can also be done, but not as efffectively.
tonyberg
Copper - Posts: 116
Posted: February 13, 2008 at 4:14 PM / IP Logged
The 2008 300C uses the new style FOBIK key just like the minivans.  If you have a vehicle like this I'd recommend a module like the IDatalink ADS-AL-CA to control door locks and pick up the door triggers via the CANBUS
stevet
Member - Posts: 36
Posted: February 13, 2008 at 7:33 PM / IP Logged
I really need to interface a starter kill on this vehicle, any idea's?
tonyberg
Copper - Posts: 116
Posted: February 13, 2008 at 7:52 PM / IP Logged
you will have to go under the hood find the wire that feeds the actual starter and interface there, the Wireless Ignition node (WIN) which is what you stick the fobik into sends a bussed message to the TIPM (totally integrated power module) under the hood and it does the starting
tedmond
Gold - Posts: 4,610
Posted: February 13, 2008 at 8:49 PM / IP Logged
the car has an immobilizer so i would say no need for one really. having a starter kill is an extra layer of security but its nice to have.
Big Dog
Gold - Posts: 1,265
Posted: February 19, 2008 at 2:19 PM / IP Logged
Wiring is same except for fobik. Do it like a 2008 Caravan.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Sunday, August 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
