autopage chirps every 10 15sec when armed
visionsss
Member - Posts: 19
Posted: February 24, 2008 at 1:04 AM / IP Logged
Installed an Autopage RF-220 in a 2000 Chevy Express Van.
Customer claims alarm chirps every 10-15secs. when armed. It is just one quick chirp. And it only does this when armed.
This is a fleet and so far I have installed 4 all the same way on the same day. I'm not sure what could be causing this. The only thing I can assume is that the alarm is defective.
Any thoughts would be appreciated.
Fred Kincaid
Visions Sound & Security
GPS Northwest
Platinum - Posts: 13,726
Posted: February 24, 2008 at 3:46 AM / IP Logged
Could it be the warning chirp of the 2 stage shock sensor?
audioman2007
Copper - Posts: 580
Posted: February 24, 2008 at 8:25 AM / IP Logged
Yea, if i was you, turn the shock sensor all the way down or disconnect it and see what happens.
Xlr8
Member - Posts: 9
Posted: February 24, 2008 at 10:58 AM / IP Logged
if it's anything like the fleets I service the rear of them are always crammed with tools, building materials, check to see if the doors are shutting properly. I had a customer concern on an intermittent dome light flicker, found he had jammed his spare tire between his toolbox and the rear door so it wouldnt roll around all of the time.
