97 Yukon SLT
almo
Member - Posts: 12
Posted: March 03, 2003 at 1:30 PM / IP Logged
Hello Everyone,
I have been able to find the wiring diagram for my truck through other threads. What I haven’t found are the resistor values for the positive door locks and how they should be wired through the relays. Any help would be greatly appreciated.
Capt. Al
Haku
Copper - Posts: 204
Posted: March 03, 2003 at 2:38 PM / IP Logged
Four door versions are positve trigger for doors, no resistor needed. Two door models are 5-wire locks, with no resistor needed. Is your a two of four door model, also what is the output from your alarm for the locks.?? Postive or Negative..
Hak
Siemens Autostart
almo
Member - Posts: 12
Posted: March 03, 2003 at 4:03 PM / IP Logged
I have the four door model Yukon and I will most likely be using the UNGO KE106. I used this model before on a stratus with positive door locks and because it was a single wire door I had to use resistors.
I just realized the Yukon has two wires.
The Ungo has 5 wires for the door lock harness thay are:
WHITE/ Black: Lock #87A (Normally Closed)
GREEN/ Black: Lock #30 (Common)
Blue/Black: Unlock #30 (Common)
BROWN / Black: Unlock #87A (Normally Closed)
Violet/Black: Lock/Unlock #87 (Normally Open) [10A fused]
How should I wire them up?
almo
Member - Posts: 12
Posted: March 04, 2003 at 9:39 AM / IP Logged
Thanks For the info. I'll take a look this weekend!
