alarm to centrallock e36.
alxz
Member - Posts: 8
Posted: April 06, 2008 at 3:28 PM / IP Logged
Hey!
As the topic says, I am installing an alarm and want to connect it to the cars centrallock-system.
The car is a BMW E36 91model.
My alarm has six different diagrams for centrallock-connection..
I'm not sure, but i think i should use "positive triggering" at this car???
Diagrams from alarm instructions:
alarm to centrallock e36. -- posted image.
I need to know whitch connection i should do, and i hope some one knows witch cables in the car that is the lock and the unlock cable for the centrallock-system ??
Sorry for my bad english..
Thank you for any answer :-)
Aleksander
Norway
Posted: April 06, 2008 at 5:02 PM / IP Logged
Its positive going, connections are inside the contol box on these early versions. If you are lucky there is a previous alarm using this.
Posted: April 07, 2008 at 5:53 AM / IP Logged
CDL relay that year is by the steering column, remove plug, pin 24 is lock pos and pin 25 is unlock pos, you will have to insert wires yourself or make up terminals.
alxz
Member - Posts: 8
Posted: April 07, 2008 at 3:35 PM / IP Logged
Hmm...
But.., i can connect the wires from the alarm between one of the central-lock motors and the central-lock unit..??
(Its 5 or 6 wires for each of the front doors..)
(the car is from mount 11 year 1991)
You talked about CDL relay.., what is that..??
Again, thanks for any answers :-)
Posted: April 07, 2008 at 4:49 PM / IP Logged
What you are suggesting is a waste of time and probably wont work because of the CDL relay to the side of the steering column.
alxz
Member - Posts: 8
Posted: April 08, 2008 at 9:31 AM / IP Logged
Well..., it won't work to connect the cables from the alarm to a unlock & a lock cable to give them 12v to lock & unlock the car..??
If i use a multimeter to test witch cables that get power when lock&unlock, and use this cables connecting to the alarm.., this woun't work???
What is the CDL relay.., and what is it's work..???
Thank you! :-)
alxz
Member - Posts: 8
Posted: April 09, 2008 at 9:48 AM / IP Logged
I have tried to search for CDL on the internet, but i do not fint mutch.... CDL doesn't mean Central Dead Lock ???
I am going to use a multimeter to test if there is outputs from the six wires in the door, and voltage soon, if someone can't tell me more :-)
Again, Thanks for all help!
alxz
Member - Posts: 8
Posted: April 09, 2008 at 2:52 PM / IP Logged
Sorry for the tripple posting.., but i do not have permissions to edit my posts... :P
Here are the result from my multimeter-testing...
Thanks a lot!alarm to centrallock e36. -- posted image.
alxz
Member - Posts: 8
Posted: April 11, 2008 at 11:15 AM / IP Logged
Well.., you right! :-)
The "CDL" relay are giving power to the locks when locking/unlocking??
More excact..., where can i fint this relay?? (It's external from the centrallock module..??)
Thank you very much!!! :-)
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
