clifford rsx 3.3 manual
jonchos
Copper - Posts: 256
Posted: May 08, 2008 at 12:23 PM / IP Logged
I am looking for this manual. Is it true there is less wires to connect to install the alarm and RS?
Thank you in advance
tedmond
Gold - Posts: 4,610
Posted: May 08, 2008 at 2:08 PM / IP Logged
not true. if you install an alarm only then its not many wires, connecting the remote start portion, will be more wires but not many.
Posted: May 08, 2008 at 4:31 PM / IP Logged
Actualy if we are using the Matrix 3.3x then there is less wiring but only if you add proprietory CAN interfaces, I've played with a couple and just downloaded the install manual. Sorry Ted.
tedmond
Gold - Posts: 4,610
Posted: May 08, 2008 at 7:03 PM / IP Logged
none take howie, you are the clifford pro.
yea i was going to mention it would be less wires only if he used a can data bypass, but not all cars are compatable and he didntmention what car so didnt mention it clifford rsx 3.3 manual -- posted image.
jonchos
Copper - Posts: 256
Posted: May 08, 2008 at 9:12 PM / IP Logged
Is for a nissan frontier 2005. I have installed several alarms in the past. All of them DEI. I just saw the new RSX 3.3 and a guy was saying how there is less wires than the 70.5X So I was curios. I will be buying one and installing it here soon. Hopefully everything will go fine.
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
