remote wiring 2006 vw golf
cyril
Member - Posts: 24
Posted: June 10, 2008 at 2:20 AM / IP Logged
Can anybody post the wireing for 2006 vw golf, I have not been able to find any info past 2004
Cyril
cyri L. Churchill
kola7126
Copper - Posts: 93
Posted: June 10, 2008 at 7:13 AM / IP Logged
 PART  COLOR LOCATION
 12 VOLT CONSTANT  RED (+)   @ FUSE BOX, LEFT END of DRIVERS DASH
 STARTER RED (+)  @ BACK of IGNITION SWITCH
 STARTER 2 N/A
 IGNITION 1 YELLOW (+) @ BACK of IGNITION SWITCH
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 GREEN (+)  @ BACK of IGNITION SWITCH
 ACCESSORY /HEATER BLOWER 2 GRAY (+)  @ BACK of IGNITION SWITCH
 KEYSENSE BLUE (+)  @ BACK of IGNITION SWITCH
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) GRAY / YELLOW (+)  @ HEAD LIGHT SWITCH
 POWER LOCK BROWN / GREEN (1-WIRE Door Lock System)  @ DRIVERS DOOR MODULE in DRIVERS DOOR
 POWER UNLOCK Same wire, See NOTE *1  See DIAGRAMS
 DOOR TRIGGER RED / GRAY (+) or RED / YELLOW (+)  @ UNDER DASH LIGHT
 DOMELIGHT SUPERVISION RED / PURPLE (-)  @ VESCM, Pin B11, See NOTE *2
 TRUNK RELEASE BLUE (-)  @ DRIVERS DOOR MODULE in DRIVERS DOOR or See NOTE *3
 SLIDING POWER DOOR N/A
 HORN BLACK/ WHITE (+)  @ VESCM Module, See NOTE *2
 TACH Any wire NOT RED / BLACK, See NOTE *5  @ Any FUEL-INJECTOR
 WAIT TO START LIGHT N/A
 BRAKE BLACK/ RED (+)  @ SWITCH above BRAKE PEDAL
 FACTORY ALARM DISARM  DISARMS with FACTORY REMOTE ONLY!!!
 ANTI-THEFT VOLKSWAGEN'S TRANSPONDER SYSTEM  @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 The LOCK is a Straight (-) NEGATIVE, the UNLOCK is a (-) NEGATIVE thru a RESISTOR, this Resistance value is not known and will need to be measured for each vehicle. To wire the Relays that are required See DIAGRAM. NOTE *2 The VESCM (Vehicle Electrical System Control Module) is part of the RELAY BOX, under the DRIVERS SIDE of the DASH. NOTE *3 The TRUNK/HATCH Release Motor wire is a RED / BLUE (+) at the CSCCM , 18-Pin Plug, Pin 4. NOTE *4 The CSCCM (Comfort System Central Control Module) is located BEHIND the GLOVE BOX. NOTE *5 The TACH Signal can also be found at any IGNITION COIL, use any wire that is NOT RED / GREEN, BROWN / GREEN or BROWN.
Posted: June 10, 2008 at 9:07 AM / IP Logged
Thanks for the info Kola, note that on Polo's and Transporters, that value is 1k.
