rv alarm door lock problem
audioinstaller3
Copper - Posts: 59
Posted: July 07, 2008 at 7:37 PM / IP Logged
I'm putting an alarm in a customers RV its a 01 Ford E450 made by Jayco. I can only get the driver door to lock and unlock using a 5 wire relay hook up. I can't get the passenger side to work. The wire colors on the car that I used were driver door lock pink/black. Driver unlock pink/orange. Passenger door lock red, pass. unlock brown. The wires test at like 1.5 millivolts. Then when I hit the switch go to 0v then directly to 12v. I tried just hooking up the door lock wires by themselves but it did nothing. I need help. The alarm is a basic autopage rf-315. Thanks
audioinstaller3
Copper - Posts: 59
Posted: July 07, 2008 at 9:47 PM / IP Logged
Could someone explain the right way to wire up a five wire door lock?
audioinstaller3
Copper - Posts: 59
Posted: July 07, 2008 at 10:09 PM / IP Logged
Ok I just found out its a 5 wire reverse polarity door lock. So how do I wire this up. Do I still use the relays?
tedmond
Gold - Posts: 4,610
Posted: July 08, 2008 at 8:39 AM / IP Logged
you will use 2 relays. and follow this diagram.
https://www.the12volt.com/doorlocks/page3.asp#5w
jim hunter
Silver - Posts: 351
Posted: July 08, 2008 at 9:42 AM / IP Logged
probably like the e150-e350 vans, red(unlock) and brown(lock) are lock unlock reverse polarity with passenger switch being master if vehicle didnt have factory keyless, if it has factorykeyless wires will be negative pink/lt green(u/l) and pink / YELLOW(l)if no keyless 5 wire relays ---pin85 to negative lock output from system, pin 86&pin87to 12 volt constant,pin 87a to switch side(side that still lights testlight when hitting lock on pass switch) pin 30 to motor(side going into driver door boot)of brown wire
use same relay wiring for red unlock except pin85 use negative unlock output from your system
audioinstaller3
Copper - Posts: 59
Posted: July 08, 2008 at 6:34 PM / IP Logged
Ok thanks I got it finished today. It was the way Jim Hunter said. So thanks for the great info.
