05 silverado alarm problems
audioinstaller3
Copper - Posts: 59
Posted: July 09, 2008 at 3:56 PM / IP Logged
It has a 5 wire door lock actuator on both doors. Lock does not work but unlock does..it double pulses it..so it locks for like a second then unlocks. Parking lights wont flash. door triggers dont work and neither will dome light when I tapped into that wire. Alarm is a audiovox something. Also to when I hooked up the relay for the starter kill using the orange-ground when armed wire I could only start the car when it was armed and could not start it when it was unarmed.
tedmond
Gold - Posts: 4,610
Posted: July 09, 2008 at 5:36 PM / IP Logged
i suggest you retest all wires. the only way the car will start when armed and not start when you disarm is because your starter kill is wire wrong.
it should be like this
85 - ground when armed
86 - ignition
87 - not used
87a - start wire key cylinder side
30 - start wire motor side
currently you have it wired for sure as
86 - ignition
87 - start wire key cylinder side
87a - not used
Mike M2
Platinum - Posts: 2,652
Posted: July 09, 2008 at 9:13 PM / IP Logged
Are you saying the actuators are aftermarket 5 wire type? If so, the reason they lock then unlock is they are adjusted incorrectly where you have them attached to the rods.
Lights won't flash, you aint telling us much. Are you using neg or pos lights? What do you have it connected to?
Again, we aren't mind readers, what do you have connected for door triggers?
Audiovox something.... ok.....
Avox starter kill, red to ignition or keyside starter, orange to orange, to two fat wires(black and WHITE/ black) to the cut starter wire, pretty simple. Are you sure you don't have arm and disarm mixed up? Disarm is 2 or 4 chirps, arm is 1 or 3...
Mike M2
Tech Manager
CS Dealer Services
audioinstaller3
Copper - Posts: 59
Posted: July 11, 2008 at 10:54 PM / IP Logged
Ok I figured it out, it was a bad alarm brain. I put in a new alarm and everything worked great. Thanks for the help
