Keyless entry problems
indiglo21
Member - Posts: 8
Posted: March 08, 2003 at 7:32 PM / IP Logged
I have a '98 Mitsubishi Eclipse and I cannot get the lock wires to work when hooked up to my keyless entry unit. My unit can be used with negative and positive wiring. I have hooked up my unlock wires and they are working fine. Any help would be appreciated.
Haku
Copper - Posts: 204
Posted: March 08, 2003 at 7:56 PM / IP Logged
Be more specific, they should be -pulse, which wires are you hooked too.
Hak
Siemens Autostart
indiglo21
Member - Posts: 8
Posted: March 08, 2003 at 8:17 PM / IP Logged
I am hooked up to the unlock wire (brown), the lock wire (BROWN / white), 12v (white), ignition (BLACK/ white), ground, and parking lights + (GREEN/ red). Everything is working fine exept when I try to lock the vechicle using the remote.
Haku
Copper - Posts: 204
Posted: March 08, 2003 at 8:21 PM / IP Logged
  POWER LOCK|RED / blue                    |-  |*1
  POWER UNLOCK|BROWN / red           |-  |*1
    *1 Located behind the glove box in a harness.
This should get you going.
Hak
Siemens Autostart
indiglo21
Member - Posts: 8
Posted: March 08, 2003 at 9:35 PM / IP Logged
I couldn't find them behind the glove box so I took the door panel off and tapped into the wires from there. Right as they come out of the lock module. Is this wrong??
Haku
Copper - Posts: 204
Posted: March 08, 2003 at 10:15 PM / IP Logged
I just checked the wiring diagram on the drivers switch, and It should work the way you have it.  I would double check your connection inside the door, and if you have a dmm, I would double check and make sure your connected to the correct wire, and also check to see if your output from the unit shows ground when you request a door lock.  If you would like, email me and i will email you back the wiring diagrams for the door locks, from Alldata.
ip3@centurytel.net
Hak
Siemens Autostart
