viper 5900 in 2002 honda accord ex
hondaspeed
Member - Posts: 33
Posted: August 16, 2008 at 6:51 PM / IP Logged
Car: 2002 Honda Accord EX coupe
Alarm: Viper 5900
RE: buttons/switches
Well, bench prep is going well... Only have two questions at the moment! :p
1.) The installation guide refers to 3 switches--2 push-type for Valet and Remote Start, and 1 toggle-type for override. The alarm only indicates it comes with one of each type. I don't think I need the toggle switch, but should I run out and buy an extra push button one?
2.) The hood pin is going to go to the GRAY hoodpin shutdown wire. I also realize now it has to also go to the BLUE (zone 4) or GREEN (door) trigger to activate the siren. I don't need to worry about isolating this though, right, since it is only one "sensor"?
Thanks.
...HondaSpeed...
hondaspeed
Member - Posts: 33
Posted: August 16, 2008 at 7:25 PM / IP Logged
OK. Think I got it. No need to use the WHITE/ Blue Remote Start activation wire with a button. Also, I will use the toggle switch to provide a ground signal to BLACK/ White neutral safety switch wire when it is in the ON position
...HondaSpeed...
chriswallace187
Gold - Posts: 1,661
Posted: August 17, 2008 at 2:32 PM / IP Logged
Precisely...also I do believe that the hood pin will trigger the alarm without any special connection.
C Renner's Auto Electronix
hondaspeed
Member - Posts: 33
Posted: August 17, 2008 at 4:11 PM / IP Logged
Thanks Chris! How are you with bypass modules? (556h) ;)
...HondaSpeed...
