Multiple Sirens
ogb1
Member - Posts: 16
Posted: March 21, 2002 at 10:29 AM / IP Logged
I have my regular siren, and a battery backed up siren currently hooked up....  i want to add a couple piezo sirens to the interior but i was told my alarm couldnt handle more then 2 sirens.  How do i put a relay in so i can add more sirens?  and do i wire the sirens up in parrallel with the sirens i have now?
the12volt
Administrator - Posts: 3,959
Posted: March 21, 2002 at 1:48 PM / IP Logged
Hi ogb1, connect a lead to your alarm's siren output. if your alarm's siren output is (+) connect it to termianl #85 and connect #86 to ground. If the output is (-) connect it to terminal #85 and connect #86 to a constant 12V+ (fused).
Connect terminal #87 to constant 12V+ (fused) and connect terminal #30 to the positive leads of the other sirens you are adding. Connect their negative leads to ground. Leave all other siren connections as there are.
the12volt
hot_shot_guy123
Copper - Posts: 114
Posted: March 21, 2002 at 1:50 PM / IP Logged
Hi there, I was on here before and I had the same question.  I have 2 external battery back-up sirens, three mini piezo sirens inside and a seperate battery just for my alarm.  People helped me so I figure I might as well help too.  The relay is easy to hook up to your alarm.  First of all you have to know if your alarm has a positive or negative trigger.
RELAY
PIN 86 = trigger wire from siren output from brain (pos or neg depending on your alarm)
PIN 85 = Ground
PIN 87 = Constant 12V  (make sure to fuse this wire)
PIN 30 = Hook up sirens to this pin
