1997 ford explorer bypass?
nbcadillac
Member - Posts: 17
Posted: September 13, 2008 at 9:52 PM / IP Logged
1997 Ford Explorer, does anybody know if it has PATS or any other system that needs bypassed? Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: September 14, 2008 at 1:01 AM / IP Logged
Yes. The easiest is the "key in the box"
JWorm
Platinum - Posts: 2,208
Posted: September 14, 2008 at 9:30 AM / IP Logged
A transponder key was optional back then. Does your key look like H72-PTO at the following link: Ford keys ? If so, it has a transponder. A key in the box kit would work, but requires a key to be given up. You can find other kits at www.bypasskit.com
