Door locks
niterunr
Posted: March 12, 2003 at 1:38 AM / IP Logged
I have a 1997 ford taurus g i just recently put an avital avistart 330 in everything works fine but when you start the car normaly (not with remote ) the alarm is supose to lock the doors three seconds after it starts   it doesnt instead if you leave the door open it will lock the doors after it starts
Any help would be greatly appreciated
1st Time Installer
Bnluis
Silver - Posts: 578
Posted: March 12, 2003 at 8:58 AM / IP Logged
it sounds like you are using the wrong door trigger wire for your alarm? Have you tested it to see if door trigger works? let me know if it helps. Follow wiring colors to fix problem.  If you are using the positive trigger for the alarm, make sure to connect to positive trigger of car, same goes for negative, but use only one not both.
                                                     Door locks -- posted image.
1997 ford taurus
DOOR TRIGGER|BLACK/ lt. blue      |+  |under dash light *1
*1 Also found lt. GREEN/ orange (-) at headlight switch. BLACK/ orange at GEM (instrument fuse panel) will get all doors and hatch on wagon. Rests at ground through ignition, cut and diode isolate.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
niterunr
Posted: March 12, 2003 at 9:59 AM / IP Logged
i will try this and let you know thanks for the reply
niterunr
Posted: March 19, 2003 at 9:21 PM / IP Logged
Door locks -- posted image. thanks very much that was it i realy appreciate the help
Bnluis
Silver - Posts: 578
Posted: March 20, 2003 at 12:11 PM / IP Logged
no problem   Door locks -- posted image.
Luis
Sound Waves
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
