burning fuses
Thack79
Silver - Posts: 526
Posted: November 24, 2008 at 8:01 AM / IP Logged
Remote starting an Mazda Rx8 04 and fused at the battery and keep burning fuses. It is amped at 30.  All other functions of alarm/keyless/auxilary channels are working except this. (12volt batterywith 10 gauge , WHITE/ blue -> starter (clutch is bypassed), BLACK / YELLOW--> ignition, Blue/Green--> accessory 1, and WHITE/ red--> accessory 2.
Any ideas???
ckeeler
Gold - Posts: 1,461
Posted: November 24, 2008 at 11:10 AM / IP Logged
how long before it burns out? or does it burn instantly when you insert it? or when you remote start does it pop instantly?
Thack79
Silver - Posts: 526
Posted: November 24, 2008 at 12:25 PM / IP Logged
not instantly, about two or three seconds into the remote start sequence it pops.
ckeeler
Gold - Posts: 1,461
Posted: November 24, 2008 at 12:33 PM / IP Logged
I wonder if 20a is just not enough fuse to pull through for the circuits in the vehicle. it probably pops right when the starter is about to crank doesnt it?
Thack79
Silver - Posts: 526
Posted: November 24, 2008 at 2:53 PM / IP Logged
exactly whats happening. but its a 25 amp  (at the battery) it blew and I didnt want to go higher to burn anything up. I hooked it up without the fuse and it blew the first 20 amp in the remote start relay. im stumped
ckeeler
Gold - Posts: 1,461
Posted: November 24, 2008 at 3:07 PM / IP Logged
What does the start wire meter when the ignition switch is in the off position? does it rest at ground with the lock cylinder not turned i wonder?
Thack79
Silver - Posts: 526
Posted: November 24, 2008 at 3:22 PM / IP Logged
factory alarm is disarmed and im registering nothing until the key is in the start position.
ckeeler
Gold - Posts: 1,461
Posted: November 24, 2008 at 4:15 PM / IP Logged
If you completly disconnect the start wire from the ignition harness does it still do it? if so either the start wire from the r/s unit is shorted, or the unit is bad and shorted internally
Thack79
Silver - Posts: 526
Posted: November 25, 2008 at 8:27 AM / IP Logged
good point. will try those things. Hard to think when your frustrated.  lol.    thanks man.
Thack79
Silver - Posts: 526
Posted: December 15, 2008 at 2:29 PM / IP Logged
Found out that it is doing it when the pink/white (ign2/access 2) comes on. blows it right away. if i leave the key in the ignition state and ground the purple on the ribbon, it starts right up. Changed units, i guess i need to get a new satilite relay.
