xk01 with 2004 yukon
bounty21
Posted: December 01, 2008 at 9:05 PM / IP Logged
i'm trying to get this thing 2 work i can get it to start for 3 sec then shuts off i have a 1400 xp python and the xk01 mod i cann't get the light to blink at all when pressing the button on the mod like it says can some one tell me and info on this
brhaugen
Copper - Posts: 275
Posted: December 02, 2008 at 6:34 AM / IP Logged
It is acting like it is not bypassing the security key.
Do the door locks work?
If so, make sure you have attached the ground while running from the RS.
If you are not getting door locks, make sure you have attached to the correct databus wire.
Reset the unit and reprogram it.
If you still get nothing, re-flash the unit with the latest firmware for your vehicle.
If still noting, the unit must be bad.(happens on occasion)
Brent Haugen
Fargo, ND
bounty21
Posted: December 02, 2008 at 10:17 AM / IP Logged
door locks don't work but the horn does i cann reprogram the mod they didn't give me the hub with the mod
brhaugen
Copper - Posts: 275
Posted: December 02, 2008 at 11:33 AM / IP Logged
Does it have the correct firmware for your vehicle?
It should be the AMDL 6 for your truck.
It should be printed on the label.
Brent Haugen
Fargo, ND
32valvefox
Posted: December 02, 2008 at 8:51 PM / IP Logged
ive had a similar issue before. is your data wire soldered?
bounty21
Posted: December 06, 2008 at 8:43 AM / IP Logged
thanks got it working got a replacement mod the other was bad
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
