2006 jeep liberty bypass problem
Memphisman
Copper - Posts: 161
Posted: December 10, 2008 at 8:41 PM / IP Logged
I just installed a Crimestopper RS-1 remote starter in a 2006 Liberty using a CH-TBU.2 bypass. The bypass programmed up properly and works if you hold it up to the ignition switch and try the RS, but it will not work if I use the loop that comes with it. I checked and it's getting power and the ground out when running is working properly. I have tried everyway that I can think of to wrap the wire loop around the ignition. Anybody of a "sweet spot" that this vehicle likes (I'm having the same issue with a 2005 Pacifica)?
jseibold
Copper - Posts: 98
Posted: December 15, 2008 at 9:54 PM / IP Logged
I've found the sweet spot.  make sure you put the loop in front of the antenna ring, not around it.  I usually use a hot glue gun to hold it in place.  should solve your problem-good luck
Memphisman
Copper - Posts: 161
Posted: December 16, 2008 at 7:09 AM / IP Logged
Thanks for the tip. I'll give it a shot.
