driver door quit convenience unlocking
mobilewizard
Posted: December 14, 2008 at 11:13 AM / IP Logged
hooked up remote start door unlock and door lock in 2008 e series van and the remote start locks and unlocks the door but the driver door quit unlocking for convenience when opened with key in on position to keep from  getting locked out.
Spellblinder
Chris Luongo
Platinum - Posts: 3,746
Posted: December 14, 2008 at 12:03 PM / IP Logged
See if the van's keysense and doorpin circuits are functioning correctly.
Ignition off, key in ignition, door open. You should hear the key-in-ignition warning chime, and of course the domelight should come on.
If the domelight's on but the chime isn't, the keysense wire might have been broken, or the (fragile) keysense switch inside the key cylinder could have gotten bent out of shape.
If the domelight's not on, maybe something with the door pin switch circuit is faulty.
mobilewizard
Posted: December 14, 2008 at 12:24 PM / IP Logged
keysence is working. I have chime and domelight. The van now locks all doors when I put the key in the ignition and turn it to on. It only used to after I began driving.
The remote start i put in is a viper 160xv. Hooked loc to pinkw / YELLOW and unlock to pink/lt. green. When I disconnect the wires it still does not convenience unlock with the driver door open and key in ignition.
Spellblinder
chriswallace187
Gold - Posts: 1,661
Posted: December 14, 2008 at 2:09 PM / IP Logged
For the convenience unlocking - try it with the key turned to on perhaps? Or disconnect the battery for a few minutes and try again.
For the automatic lock with ignition on - the Viper is probably controlling the locks there. If you'd like to disable this it can be done by changing the program settings on the Viper.
C Renner's Auto Electronix
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
