2004 gmc sierra pass lock problem
cat70532
Posted: December 14, 2008 at 2:29 PM / IP Logged
I have installed a viper 571xv and the 1700G bypass module and everything is working but the problem i am having is that when you turn off the ignition after driving the doors lock right away and the pass lock system is armed.  i would like to find a way to get it back to the standard gm setting that unlock the door when the engine is shut off.  any ideas, i'm thinking its just a setting by i cant seem to get it.
Thanks fir your help,
Craig
cat70532
Posted: December 14, 2008 at 2:31 PM / IP Logged
also the truck is a 2004 gmc seirra
cat70532
Posted: December 14, 2008 at 2:39 PM / IP Logged
https://www.the12volt.com/installbay/file.asp?ID=548
this is the link for the installation guide
chriswallace187
Gold - Posts: 1,661
Posted: December 15, 2008 at 12:18 AM / IP Logged
It sounds like you have your lock/unlock wires backwards maybe going to the 1700G? They shouldn't ever lock with ignition off, just unlock.
C Renner's Auto Electronix
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
