02 sunfire remote start
nissanman98
Member - Posts: 7
Posted: December 19, 2008 at 7:38 PM / IP Logged
Just bought a valet remote start and want to install myself could anybody tell me what bypass I need and any other tips to make this go smooth.
Bo
tedmond
Gold - Posts: 4,610
Posted: December 19, 2008 at 11:06 PM / IP Logged
passlock bypass is what you need. there are many to choose from. most popular brands would be Fortin, Bypasskits, idatalink, etc.
chriswallace187
Gold - Posts: 1,661
Posted: December 20, 2008 at 3:19 AM / IP Logged
Ignition switch harness wires are somewhat of a bitch. If you don't have a tilt column - take the shroud off, unplug the ignition harness, and pull the wires through to make your connections. If you have a tilt column, make the connections to the ignition harness upside down(you'll either break or severely scratch the tilt wheel lever trying to remove it).
Parking lights, brake lights, lock, unlock are all readily accessible in the orange taped harness to the rear on the driver's side. Driver's doorpin, if you feel like doing RAP shutdown or other need, is in a two pin harness going to the pin switch itself.
Wires through the firewall for tach/hoodpin: This is the easiest car in the world. Notice the gigantic 5" wide gray grommet that only has 1" of wires. Poke a hole and go through there, preferably dragging your wires with a coathanger.
Tach: regardless of what engine, look for the ignition module connector towards the driver's side. PURPLE / white wire.
C Renner's Auto Electronix
kassdog
Copper - Posts: 257
Posted: December 20, 2008 at 10:23 AM / IP Logged
Another tip is that you can get your ignition wires and p. lights at the harness going through the firewall. There is a little piece of loom that comes right off. Thats where I always grab my ignition and p. lights in the sunfire/cavalier. Also I've always like the 555lw by dei. Not sure if they still make that though.
sonnyb
Posted: December 24, 2008 at 5:45 AM / IP Logged
I have sunfire 2001 Just want to check where can find th all the wires and what i need to open to reach the wires i have circuit diagram .Also i need to bypass the security of the car as well. I want to know what i need for that and where can i get the by pass module.
techi
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
