pc programming python 1500 esp
exfsiguy1
Posted: January 08, 2009 at 1:15 PM / IP Logged
Hello all,
I have a working Python 1500 ESP that is going to be utilized in a different application from the original install. The documentation says that the 3 pin connector supports either a Bitwriter(?) or PC communications. Anyone have any experience in the PC connection?
Do you need some form of "dongle"?
Is it just Tx, Rx, and ground? If so which pins are which?
Do you use hyperterminal?
Any input/help is appreciated.
Thanks again,
Terry
exfsiguy1
exfsiguy1
Posted: January 08, 2009 at 1:17 PM / IP Logged
Oops,
Also (if applicable) baud rate, parity, etc
Terry
exfsiguy1
loneranger
Copper - Posts: 572
Posted: January 09, 2009 at 12:04 AM / IP Logged
This is actually a module converting the protocol from the PC RS-232 interface to the protocol on the ESD RS-232 interface. I haven't seen it and it been discontinued for awhile now. It does require an application on the PC.
exfsiguy1
Posted: January 09, 2009 at 9:52 AM / IP Logged
Hello,
Thanks for the quick response. I didn't think it sounded easy or viable, considering the lack of info available. I was just being lazy, wanting to use tools to make a job easier.
Great site by the way, and I'll be posting whenever possible.
Thanks again,
Terry
exfsiguy1
