2004 chevy blazer, autostart as-1775
scottys
Posted: January 14, 2009 at 5:56 PM / IP Logged
This is my first time with passlock 2003 I am installing autostart AS-1775 in a chev blazer 2004 I need help with the pass lock part of the install and seting it up can you help
skippy64
moonliter
Copper - Posts: 322
Posted: January 14, 2009 at 7:00 PM / IP Logged
https://ifar.ca/en/download/96/installation_manual.rev-1.2b.pdf
You only need to use 4 wires from the passlock 2003.
  • black ----- black OR BLACK/ orange at the passlock 2
  • yellow ---- yellow wire at the passlock 2
  • white ----- ( not required ) as long as ign2 is wired up from AS-1775
  • pink ------ ignition at the ignition switch harness
  • purple --- ( not required )
  • brown --- ( not required )
  • blue ------ Ground while running ( white wire of the 12 wire harness of AS-1775 )
  • green ---- ( not required )
make sure the jumper is set on mode 1, after all the connections are made, start the vehicle with key and then adjust the port till the led turns off. If you keep turning the pot, the led will come on again. The sweet spot will be in between the led starts to turn off.
scottys
Posted: January 14, 2009 at 7:43 PM / IP Logged
Thanks for the info will try this in the am, muchly appreciatted
skippy64
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
