backup siren 515esp pics inside
trim81
Posted: January 16, 2009 at 3:13 AM / IP Logged
I have a Clifford Matrix 3.5
1) Hooked up red to constant 12V
2) Hooked up black to ground
3) Hooked up Orange TX wire to brain's BROWN wire (siren output)
---did the above, but my backup siren does not work????
Anyone have any ideas where I went wrong?
I have this uni (view the pic)t:
http://cgi./DEI-515ESP-BACK-UP-BATTERY-SIREN-Viper-Clifford-515R_W0QQitemZ350151023857QQihZ022QQcategoryZ60203QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
trim81
Posted: January 16, 2009 at 3:15 AM / IP Logged
(dont know how to edit, but this is the link to my 515ESP)
backup siren 515esp pics inside -- posted image.
Posted: January 16, 2009 at 1:53 PM / IP Logged
Doesn't the siren come with a specific plug to be plugged directly into the unit? The brown you've used is a 12V+ on siren sounding,  the orange sits on ground and is data. The brain or siren is probably US by now.
trim81
Posted: January 16, 2009 at 2:20 PM / IP Logged
what the heck? so should I remove the orange wire ASAP?
my alarm looks like it is working now...how do I test the siren manually?
ALso, which wire do I need to tap the orange TX into (from my brain?)
---The harness didnt fit my brain, so I had to cut the harness.
Please help!
Posted: January 16, 2009 at 3:38 PM / IP Logged
Thanks for the picture, the wiring assembly in the plastic bag should plug into a ready made port for it in the main module, except I've just looked at one via directechs and there doesn't seem to be a port for it!  I'm afraid that come Monday you will have to phone DEI tech support and get any info. Sorry.
trim81
Posted: January 16, 2009 at 3:41 PM / IP Logged
typically, do I tap into the brown siren wire or the brain's BLUE wire? TX?
(ive tried both, and the dam siren is not working)...
anyone?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
