aztek gauges dont work
davedog33
Member - Posts: 9
Posted: January 24, 2009 at 6:59 PM / IP Logged
I installed a rs in a 2003 pontiac aztec and every thing works fine, except the gauges. The tach gauge, fuel gauge and temp gauge do not register anything even if I start it with the key. I installed a Ultra Start 1280 RX Pro, and used a GM-SL bypass. I also soldered all connections The Ultra Start comes with 2 ignition wires, and i used a relay for the third ignition. The GM-SL is only controling the park lights and the passkey3. Any help would be great! Thanks
loneranger
Copper - Posts: 572
Posted: January 24, 2009 at 8:53 PM / IP Logged
I'm not sure if that vehicle has a 3rd ignition. It does have 2 accessories, though. However, that doesn't matter, as your issue still arises when manually started. My guess is you may have inadvertently pulled a plug from the cluster panel or worst case damaged the ECM somehow.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
davedog33
Member - Posts: 9
Posted: January 24, 2009 at 9:00 PM / IP Logged
I used the wire colors from this site, and it lists 3 ignition wires and 1 acc. wire, but after looking around in the forums, and from what your telling me, I may have a 1 too many ignition wires hooked up and 1 less acc. wire hooked up.  Do you think this could be the cause for the gauges not working though?
loneranger
Copper - Posts: 572
Posted: January 24, 2009 at 9:26 PM / IP Logged
No. As I stated in my previous post, that doesn't matter, as your issue still arises when manually started.
davedog33
Member - Posts: 9
Posted: January 25, 2009 at 12:27 PM / IP Logged
I disconnected the negative battery cable for ten minutes or so, and all is good now! Thanks for the help
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
