schematics needed, 2000 dodge durango
edaddee
Member - Posts: 29
Posted: January 31, 2009 at 11:46 AM / IP Logged
For anyone that can provide exact schematics(drawn diagram) for a 2000 dodge durango, for alarm/remote start for the diodes/relays (as i'm a novice at installing alarms), I would greatly appreciate it as I will be leaving monday going out of town to do a few alarm/remote installs, but have never had one that needed multiple extra diodes/relays to work. Thanks in advance
robertsc
Copper - Posts: 337
Posted: January 31, 2009 at 1:12 PM / IP Logged
look above its says vehicle wiring
or try the search option
edaddee
Member - Posts: 29
Posted: January 31, 2009 at 2:54 PM / IP Logged
already got the detail of the wiring itself, but i can't find anything other than what ohm resistors to wire in and that i need relays. like i said, just a novice @ the alarm/convenience installs. Also, i did multiple searches using dif keywords, but no luck thus far
edaddee
Member - Posts: 29
Posted: January 31, 2009 at 3:13 PM / IP Logged
also, can anyone tell me how to wire multiple resistors to get the ohm value needed for installation? and within what tolerance can they be?
edaddee
Member - Posts: 29
Posted: February 01, 2009 at 12:47 PM / IP Logged
anyone, please? leaving tom, mid-day, and i'd rather have something to go off of, than to be guessing
robertsc
Copper - Posts: 337
Posted: February 01, 2009 at 2:45 PM / IP Logged
theres lots of info here try looking around i know it make take several minutes
but its here
Platinum - Posts: 13,726
Posted: February 01, 2009 at 3:30 PM / IP Logged
The tolerance of most door lock systems is pretty forgiving, I have seen them be as far as 20% out and still work.
schematics needed, 2000 dodge durango -- posted image.
edaddee
Member - Posts: 29
Posted: February 01, 2009 at 3:40 PM / IP Logged
but its here
i'm sure the answers to the questions i'm asking may be here, but the phrase or keywords i'm using to search with just aren't pulling up what i need. I was under the assumption that if I couldn't find the answer after searching, I was entitled to ask a question, to see if someone that might actually know the answer could steer me in the right direction or share the knowledge they have, not back to the search option.
I appreciate all the "help"
Posted: February 01, 2009 at 4:04 PM / IP Logged
schematics needed, 2000 dodge durango -- posted image.Power UnlockGREEN/ ORANGE(-)HIGH IN DRIVERS KICK IN BLACK PLUGschematics needed, 2000 dodge durango -- posted image.
schematics needed, 2000 dodge durango -- posted image.PowerLockSAME WIRE(-)HIGH IN DRIVERS KICK IN BLACK PLUG
LOCK/ARM IS NEGATIVE TRIGGER THRU A 650 OHM RESISTOR. UNLOCK/DISARM IS NEGATIVE TRIGGER THRU A 1560 OHM RESISTOR. MUST USE RELAYS. UNLOCK REQUIRES A DOUBLE PULSE.
edaddee
Member - Posts: 29
Posted: February 01, 2009 at 10:05 PM / IP Logged
thanks, i am an idiot, I appreciate the quick response and help on the subjects at hand. Like i said, i'm just a novice, so it really helps
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
