adding power door locks
sworrix222
Member - Posts: 15
Posted: February 21, 2009 at 3:27 PM / IP Logged
i have a 2004 chevy silverado base model i also have a valet 562t remote start i purchased 2 2 wire actuators can any one tell me how to wire the door locks with no switches inside the car will the green and blue wire run both door lock actuators..it has a relay satelitre do i need to run seperate relays????thanks shawn
t&t tech
Platinum - Posts: 2,622
Posted: February 21, 2009 at 5:36 PM / IP Logged
adding power door locks -- posted image.use this diagram, the blue connects to the unlock output, and the green to the lock.
loneranger
Copper - Posts: 572
Posted: February 21, 2009 at 6:42 PM / IP Logged
To further simplify, the R/S's BLUE unlock/lock wire goes to the unlock relay. The R/S's GREEN lock/unlock wire goes the lock relay. If the actuators are operating in reverse, then swap the R/S's BLUE and GREEN wires.
Ideal - cmon dude, add to topics in a useful manner, not stuff that is obvious.
Story - Phzzzt! Hey, what happened?! ... Isn't it obvious?
Moral - Never dismiss the obvious.
Posted: February 22, 2009 at 2:23 PM / IP Logged
You can get really flash here and run a single pole double throw momentary switch accross the green and blue 526 lock output wires before the relay, just ground the centre contact, or use a 5 terminal Spal window switch, ground the centre contact and feed to the two outers. Sorry that nitro BMW guy has teed me off.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
