2001 Durango HVAC
Smitty3572
Member - Posts: 16
Posted: March 21, 2003 at 12:52 PM / IP Logged
I have looked over all the forums and have searched for 2 days with no luck. I got a copy of thr wiring harness for the 2001 Durango and everything has been great except 1 thing. The second ignition connection and the secong aux connections. Do they hook up through a relay from my alarm Ign./Aux signals on alarm system. Or are they used to assist the HVAC blowers? I hope this info makes sense. Thanx for a great forum.
Smitty3572
auex
Platinum - Posts: 5,041
Posted: March 21, 2003 at 7:52 PM / IP Logged
What kind of alarm do you have? And clarify if you mean outputs from the alarm or if they are wires in the car. Second ign wire in the car will control ac/heater.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
securinu
Silver - Posts: 772
Posted: March 21, 2003 at 9:39 PM / IP Logged
Green
is the wire you need to hook up for the ac to work
Joe O'Byrne
Owner / Installer
Smitty3572
Member - Posts: 16
Posted: March 22, 2003 at 8:57 AM / IP Logged
OK. I connected everything. The a/c wires are green and BLACK/ or (front/back) everything works great. But last night i did have a problem with the alarm sounding with door intrusion. I connected the door signal wires (2)with diodes. The alarm type is Jazz. New mfr out with great features. My communication with the alarm is 2way from around 100 yards easily. Any ideas on the premature triggering?
Smitty
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
