Opinions on clamp connectors
awd_sr
Copper - Posts: 84
Posted: June 04, 2002 at 7:02 PM / IP Logged
I'm ahout to install an alarm in my Altima and Cherokee and I wanted to check with you guys about those clamp connectors.  The ones where you just place the connector over the wire you want to splice into, and you put the wire from the alarms harness in the groove, then clamp it shut with pliers.
Is it best to solder the connection and tape or heat shrink?  Thanks
bberman1
Gold - Posts: 2,314
Posted: June 04, 2002 at 10:21 PM / IP Logged
awd_sr
Copper - Posts: 84
Posted: June 04, 2002 at 11:05 PM / IP Logged
cool, thanks bberman1, this will definitely help out
Moderator - Posts: 12,488
Posted: June 04, 2002 at 11:14 PM / IP Logged
NO TO T-TAPS !! BOOOO !! Opinions on clamp connectors -- posted image. Solder all connections for the best results Opinions on clamp connectors -- posted image.
awd_sr
Copper - Posts: 84
Posted: June 05, 2002 at 6:24 AM / IP Logged
thanks Jeff, I'll take those back to Radio Shak and get my 1.98 back  :)
Thanks again u guys!
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
