viper 791vx, 2000 chevy silverado
2kz71
Member - Posts: 22
Posted: March 18, 2009 at 10:27 PM / IP Logged
Okay i just recently bought a Viper 791VX with remote start...i have done a few allarms before but never a remote start system. This is all going into a 2000 Chevy Silverado
Now for the questions....
I've read a few things on the factory GM passlock system and how you have to bypass it. I know there's a kit from DEI you can purchase to bypass it but i was wondering if there's any other way around that?
The allarm system also came with (2) window control modules. I want to be able to roll my windows down before i get into my truck (i live in california) during summer, and roll them up when i leave the truck...
On the unit itself it has these wires:
Pink-to accessory item
Green-Left motor
White-Left switch
Orange-500ma Activaticn
Black-Ground
Red-Constant
Blue-Right motor
Brown-Righ switch
It says to cut the wire for the right motor and switch, do i need to do this for both the right and left windows?
What do i hook up the pink and orange wires to? I'm sure the orange probably needs to be hooked up to an accessory output off the brain of the allarm...or no?
I know there's more questions but i'll start with these....thanks in advance!
t&t tech
Platinum - Posts: 2,622
Posted: March 19, 2009 at 5:27 PM / IP Logged
yes you need to cut the wires for both windows, the pink wire is unused, the orange wire you hook to the RED / white wire from the 791xv primary harness. and there is another way around the passlock, but it will permanently defeat the passlock system.
2kz71
Member - Posts: 22
Posted: March 19, 2009 at 7:51 PM / IP Logged
what would be the point of keeping the passlock system?
t&t tech
Posted: March 19, 2009 at 9:34 PM / IP Logged
it's there to prevent thieves from stealin ur car, if this isn't an issue well, then there is no point to keeping it.
2kz71
Member - Posts: 22
Posted: March 19, 2009 at 11:10 PM / IP Logged
......wouldn't installing an allarm be the same thing?
i saw a few how-to's on using a number of relays to bypass it instead of getting the bypass module (5 bucks per relay or 50+ for the module....i'm broke btw) ...is that the easiest way or is there a way to just chop the whole thing out?
ajstetler
Copper - Posts: 94
Posted: March 19, 2009 at 11:56 PM / IP Logged
Bypassing a factory immobilizer is a little more difficult than hot-wiring the starter wire to start the vehicle if you are a garden-variety thief. You also have to remember that the Passlock information gets sent to critical components in the vehicle and when you start messing with, such as trying to permanently bypass it, you are asking for a bunch of problems. Save yourself some headache and purchase a $50 bypass and be done with it. You may want it cheap but you get what you pay for. Just some professional advise-it's your truck.
Big Al
2kz71
Member - Posts: 22
Posted: March 20, 2009 at 2:03 AM / IP Logged
did you just call me a thief?
t&t tech
Posted: March 20, 2009 at 6:17 AM / IP Logged
ok let me break it down for you, the bypass would allow only allow you to remotely start the vehicle, and still prevent a hotwiring attempt, wheras permanently bypassing the passlock would allow remote starting and hotwiring to succesfully start the vehicle, making it easy prey for thieves, but as i said earlier, if the vehicle being stolen is not an issue then you can go ahead and do the permanent bypass, ths would be the relay, resistor method.
ajstetler
Copper - Posts: 94
Posted: March 20, 2009 at 9:13 AM / IP Logged
[/QUOTE]
What?? You completely took what I said out of context. Read it again and maybe understand what I am trying to say. I am referring to someone who would attempt to steal a vehicle. It would be more difficult to hot-wire a vehicle with a factory immobilizer like Passlock, than having nothing at all. CHILL OUT.
Big Al
2kz71
Member - Posts: 22
Posted: March 20, 2009 at 8:01 PM / IP Logged
got it...until this point i was under the impression that the passlock system was basically just a factory allarm system...thanks for clearing that up for me.
