door lock and unlock
emorse2323
Copper - Posts: 106
Posted: June 11, 2009 at 3:32 PM / IP Logged
I am trying to hook up an alarm on a 2006 mercury mountainer to a K9 Mundial SS and am having problems getting the doors to lock and unlock it is not working Im assuming I need relays and tryed a few different ways and have still not gotten them to work. Any help is appreciated.
joch1314
Copper - Posts: 301
Posted: June 11, 2009 at 4:01 PM / IP Logged
Power unlock is PURPLE / gray ( - ) in the DKP.
Power lock is gray / YELLOW ( - ) in the DKP.  You can also get them both from the SJB (smart junction box) connection B.  unlock is pin 26 lock is pin 27.
Which wires are you tapping into?
...half of the truth can be worse than a lie. <----Roger Russell said that..
emorse2323
Copper - Posts: 106
Posted: June 15, 2009 at 8:47 AM / IP Logged
Those are what im using it will un-lock fine but dosent lock we tested the wires and its deffently them but can't get it to work?
chev104275
Gold - Posts: 1,436
Posted: June 15, 2009 at 11:28 AM / IP Logged
did you test the lock output of your system ?   make sure thats putting out a ground pulse when you hit the button
