98 chrysler sebring lxi coupe viper 5601
md1gs
Posted: July 02, 2009 at 4:15 PM / IP Logged
Does anyone have remote start wiring info on a 98 chrysler sebring lxi coupe? And will i need a bypass to install a Viper 5601 in my car?
md1gs
Posted: July 02, 2009 at 10:08 PM / IP Logged
i've instaled keyless entry and alarm systems and alot of car audio before but never an auto start. It doesn't seem that hard, but some people are telling me that i need a bypass and some others are saying i don't, can i install this auto start without a bypass?
ckeeler
Gold - Posts: 1,461
Posted: July 06, 2009 at 9:34 AM / IP Logged
if you look at the top of the page under "vehicle wiring" you will find the wire info you need for the vehicle you are working with. you wont need to use any type of bypass for the coupe.
md1gs
Posted: July 09, 2009 at 7:31 PM / IP Logged
Ok i finally have it all hooked up and everything works great, only problem is i can't figure out how to get the doors to lock/unlock. my car has the 3 wire negative system- and this viper has positive outputs. This car came with a keyless entry system so i found the relays that show a positive charge when the car is locked/unlocked. but when i connect the viper to these wires the doors don't unlock/lock but i did set off the factory alarm. can anyone help?
Platinum - Posts: 13,726
Posted: July 09, 2009 at 8:04 PM / IP Logged
the12volt
Administrator - Posts: 3,959
Posted: July 09, 2009 at 8:21 PM / IP Logged
Topic moved to Car Security forum.
98 chrysler sebring lxi coupe viper 5601 -- posted image. the12volt • Support the12volt.com
