alarm door locks don't work properly, 98 neon
belalegosi
Member - Posts: 19
Posted: July 10, 2009 at 1:11 AM / IP Logged
I installed my alarm on my 98 neon and it works fine. The only problem is the door locks seem to be "weak".
At first only the front doors would lock/unlock with the remote. The rear doors seem to be unaffected.
Now after a month or so the front passenger door does not lock properly. The lock would not go all the way down.
The car has power door locks and they lock/unlock all the doors perfectly no problem. So its the alarm set up giving problems.
I used this set up to assemble the relays for the locks: https://www.the12volt.com/12voltimages/5wap.gif
I tapped into the door lock wires at the driver kick panel 16 pin connector.
What could be my problem?
ckeeler
Gold - Posts: 1,461
Posted: July 10, 2009 at 8:53 AM / IP Logged
it sounds as if you have the wrong wires. do you remember what colors you used?
belalegosi
Member - Posts: 19
Posted: July 10, 2009 at 12:34 PM / IP Logged
This is from by the driver's kick panel:
Door Lock: Pink/Purple
Door Unlock: ORANGE / Purple
ckeeler
Gold - Posts: 1,461
Posted: July 10, 2009 at 12:53 PM / IP Logged
ORANGE / purple should be lock
pink/purple should be unlock
how did the wires meter when you tested them? did you use a meter to test them?
belalegosi
Member - Posts: 19
Posted: July 10, 2009 at 1:06 PM / IP Logged
with a meter:
pink/purple went to 12V when lock was activated via door switch
ORANGE / purple went to 12v when unlock was activated
ckeeler
Gold - Posts: 1,461
Posted: July 10, 2009 at 3:24 PM / IP Logged
keep looking for others wires. those are not the right ones.
belalegosi
Member - Posts: 19
Posted: July 10, 2009 at 3:57 PM / IP Logged
What would be the right ones?
Those are the wires the Haynes Manual listed as the door lock/unlock.
ckeeler
Gold - Posts: 1,461
Posted: July 10, 2009 at 4:07 PM / IP Logged
yes but did you confirm that through testing them? there may be another set of wires you need to get that happen to be the same colors, or.....the relay setup could be wrong. with only one of the wires that you think to be the ones, disconnect it from its corresponding relay so that you have to halves of the wire but do not connect them, operate the switch and tell us how the locks  behave.
richl68
Copper - Posts: 107
Posted: July 11, 2009 at 9:39 AM / IP Logged
Do you have a 451M on hand to try inplace of the relay setup that you tried??
look over your wiring and make sure everything is good, wiring to 12volts is properly connected and such.
belalegosi
Member - Posts: 19
Posted: July 11, 2009 at 1:10 PM / IP Logged
I did look over the wiring and everything seems fine.
The driver's door lock and unlocks with the alarm as it should. The front passenger unlocks like it should but seems to not get enough "juice" to lock.
The rear doors are unaffected:(
I'll check over the wiring again when it stop raining
