1998 Yukon Passkey II bypass
dfrates
Posted: March 27, 2003 at 1:55 PM / IP Logged
Just installed a Valet 552t remote start with the DEI 555l Passkey bypass. The vehicle will start and then stall when starting using the remote start. If I leave the key on in the ignition, then start using the remote, the system works fine. I can even take the key out . I have the 555l install manual and I believe everything is hooked up correct. Help PLEASE !!!!!
dfrates
Platinum - Posts: 12,488
Posted: March 27, 2003 at 2:24 PM / IP Logged
What wire did you use for the activation wire for the 555L ?
dfrates
Posted: March 28, 2003 at 3:27 PM / IP Logged
Jeff, I hooked it up to the blue wire from the 552t. Now I am wondering if I hooked it to the correct blue wire !! There is one in each of two harnesses. I am going to attempt to repair on Sat. morning if you can be of any help, it is greatley appreciated. Thanks, Dennis.
dfrates
Posted: March 30, 2003 at 9:53 AM / IP Logged
You should use the H3 BLUE/BLACK wire on the Valet 552T for the 555L activation wire. The BLUE wire can be programmed for the 555L but the BLUE/BLACK wire is already for hook up to the 555L.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
