2001 Honda Odyssey Remote Start
chunwing
Posted: March 29, 2003 at 6:41 AM / IP Logged
I'm looking for wiring diagram info. on a 2001 HOnda Odyssey to install an audiovox prestige aps685 remote starter.  Thanks for any help.
wing.
Bnluis
Silver - Posts: 578
Posted: March 29, 2003 at 10:20 AM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|BLACK/ white         |-  |green 6-pin plug *1         |
|     POWER UNLOCK|GREEN/ red           |-  |green 6-pin plug *1         |
|       LOCK MOTOR|WHITE/ red           |   |green 10-pin plug *1        |
|     UNLOCK MOTOR|lt. GREEN/ red       |   |green 10-pin plug *1        |
|    DISARM DEFEAT|lt. GREEN/ red       |   |green 14-pin plug *1        |
| PARKING LIGHTS +|RED / black           |   |10-pin plug *1              |
|       HEADLIGHTS|blue/red            |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white         |-  |domelight on/off switch     |
| DOME SUPERVISION|lt. green           |-  |domelight on/off switch     |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|yellow/red          |-  |right of steering column    |
|TRNK/HTCH RELEASE|*4                  |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|blue                |-  |DDM in driver door          |
|       TACHOMETER|blue                |   |above the brake master *2   |
|      SPEED SENSE|blue/white          |   |PCM *3                      |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|blue and blue / YELLOW|-  |steering column             |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |drivers window motor        |
|  RF WINDOW UP/DN|blu/wht - blu/yel   |A  |RF window switch            |
|  LR WINDOW UP/DN|grn/red - grn/yel   |A  |LR window switch            |
|  RR WINDOW UP/DN|RED / blu - RED / yel   |A  |RR window switch            |
|        RADIO 12V|WHITE/ blue          |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|WHITE/ red           |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - brn/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555H or 555U.  *1 The plug is located at the bottom of the fuse box.  *2 In a 2-pin test connector.  *3 The PCM is located in the center console.  The speed sense is located in a 32-pin plug.  *4 To open and close the power sliding door with a single channel see directfax document #1085.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
