dei 530t on 01 Chrysler sebing
pincky
Member - Posts: 25
Posted: March 30, 2003 at 8:30 PM / IP Logged
On my 01 chrylser sebing lx i have a factory alarm with keyless entry and i don't have a ground when arm output. it said i can hook up to my lock wire.. but when i start driving the door locks automaticly is that gonna effect the window roll up module? is there a way to hook it up so when the car is off it will work but as soon as i turn the car on it would cut off power to the roll up module so if i have the windows down and i start drivein and when the doors lock it wouldn't start rolling up the windows? thanks!
vince
themagicone
Silver - Posts: 325
Posted: March 30, 2003 at 9:14 PM / IP Logged
First, your going to need to get a pulse timer to roll the windows up on lock - a one sec pulse won't do it. As for not having roll up when your car is running you can install a relay that disconnect the unit from the locks.
